07 gearing...
10 replies to this topic
  • redswr
Posted November 15, 2008 - 11:33 PM
sorry for not searching but just had a quick question...
what ratio do i need to make 1st feel like 2nd? i do mostly dune riding so i like speed and never touch first and usually don't even touch 2nd... oh and also i'll have a different wheel set up for offroad so i'd like a little lower than dune gearing there with out changing the front sproket.
  • stev0
Posted November 16, 2008 - 01:59 AM
I run a 15 - 50, on the dunes its the bussiness. I still pullaway in 3nd though.
  • desdave
Posted November 16, 2008 - 03:59 AM
Your 07 (and my 08) WR came with 13/50 stock. General rule of thumb...3 teeth on the rear is about equal to 1 on the front (divide rear # by the front # equals final drive ration). Anyway, what stevh0 is runnings is very close to what you would get with 13/44. By the way, if your chain has enough adjustment in it, see if you can borrow a 15 from a buddy and try it.....cheaper than a new rear only to discover it isn't what you were looking for.
  • AnthonyB
Posted November 16, 2008 - 08:37 AM
Use a 16 front sprocket and you'll get as close as dammit to what you're after:thumbsup:
  • redswr
Posted November 16, 2008 - 12:40 PM
ok so i should get a 13 front and then a 44 rear on my dune wheel and the stock 50 on my dirt wheel?
  • desdave
Posted November 16, 2008 - 12:52 PM
What is your current gearing?
  • redswr
Posted November 16, 2008 - 02:01 PM
it's stock...
  • desdave
Posted November 16, 2008 - 06:30 PM
If your working with your 07 wr, then you should have a 13 front stock, 50 rear, so drop the rear to a 44 will give you almost exactly the same ratio as going to 15 front. Any more and I think you'll be over geared.
  • redswr
Posted November 16, 2008 - 07:06 PM
ok thanks... I'll stick with the 50 for my dirt wheel and a 44 for my paddle.
  • Regalman
Posted November 17, 2008 - 10:19 AM
How many links is the stock chain?
  • 123BigcoopDawg576
Posted November 17, 2008 - 10:46 AM
114 :thumbsup:
