SavageSS said:
Wrong, read all the thread :moon: it was dis-proven, I also did this mod and re-did my measurements. Did absolutely nothing.....
Hope fully someone will do photo comparisons for this mod..
http://www.thumperta...ghlight=r6+tube
bklynpath said:
Dude, trust me I did the same r6 mod. It worked for me. :banana:
Entirely correct.....the R6 mod works:banana:
I'm wondering if the throttle you got was really the R6 part?? Maybe there was a mixup in what you received?:banghead:
As to the zip-tie mod..........the reason it works is that it increases the diameter of the throttle plastic where the cable rides, therefore pulling more cable than the stock model.
Where the danger arises is if......or when that piece of zip-tie becomes loose, it might wedge against something, therefore jamming your throttle in the stuck position. This could be at idle, or wide open, or anywhere in-between.
Stuck wide-open-throttle and you are in for a WFO Experience:busted: that they may scrape your remains up off of the asphalt with a snow shovel (geeze.....I always wondered why tow trucks carried those snow shovels anyway):cripple:
Me thinks that this is a cheap mod that me gonna' pass up....if I want "more twist" I'll go the R6 route:smirk:
HappyRiding !!
:ride: :ride:
