good day today.received the cylinder works bb kit and hot rod 5mm stroker crank.:banana:
depending on angle of piston in the bore,the bottom of piston pin boss will barely scuff or rub on crank web at bdc.:banghead:
-cylinder works says 0.040 clearance needed but unsure of #(i'm not an engineer he says)
-wiseco stays quiet as they manufacture piston to cylinder works specs so ask them instead.wiseco only says 0.180 minimum thickness on bottom of pin boss should remain(ball park # as it depends on engine)this is exactly what is on this piston.
- are there no thrust washers on the big end of crank?
anyone with this combo out there cares to chime in?
otherwise everything looks good.cylinder works kit seems decent quality but time will tell.
