reconranger said:
The VIN is stamped on the head of the frame and that is what defines it as a vehicle, so I would assume that this would be considered a whole new bike (????). In other words, the bike is the frame, no mater what engine or other components you swap in or out of it.
Birdy426 said:
Same model, same year. Go to the DMV and complete a "Statement of Facts" form that says you replaced frame VIN XXXXXXXXXX with frame VIN YYYYYYYYYYY (the model and year are reflected in the VIN). They will issue a new title and registration reflecting the new VIN. If your bike was plated before the Feb 04 "deadline" you should be fine. If it was plated thru the cracks after the deadline, there's a chance you will lose your plate.
Does anyone have personal knowledge about this? It is my understanding from reading the available DMV info that the plate could be pulled if this is done. It used to be possible to do the frame switch thing, but that was before 2004. Today they pull every plate that they can for any reason. From what I have gathered even am engine number change is grounds for pulling the plate.
Now I could be wrong. I'm no lawyer and I don't even play one on TV. Most of the above is based on things that I have heard, and trying to read state documents.
