Headlight bulb upgrade for DRZ400K?
21 replies to this topic
  • ruddell07
Posted 12 November 2008 - 07:08 AM
I've done alot of searching on DRZ headlight bulb upgrades and found great info for the S, SM, and E models. I was wondering if anybody has any suggestions for going to a brighter bulb on the K model. (Yes, someone actually bought a DRZ without the button and battery.) The bulb is different than on the E model with just the two nubs on the bottom and a H3 style won't work, but I believe its the same specs 12v 35w. Any superior knowledge would help. Thanks.
  • Fast_Richie
Posted 12 November 2008 - 11:13 AM
just wondered if you had a picture of the bulb. I think I know which bulb it is and I think the brightest you can go will be 45w.
by the way I love the K model.. wish I had one but for the road its hard to think of life without that button.. :D
  • Noble
Posted 12 November 2008 - 11:26 AM
I never pass the oportunity to point out "K" is a year code for a DRZ400 not model. However, the kicker model has the same head light as the early E model and is 55 watts. As far as I know, the replacement bulb is only available from Suzuki.
  • Devondan
Posted 12 November 2008 - 12:08 PM
Not so I expect it is the H3 bulb, mine was. In some cases the H6M will fit as a straight swap and give you main and dip.
My Kicker (no need for that woosy electric start!) is a 2001 and had the H3(C?) bulb I bought an H6M and carefully reshaped the seating ring on the bulb with a dremel and soldered two connectors to the bulb, I also had to widen the aperture in the headlight bulb holder as the H6m bulb is a little fatter but I now have main and dip for £6 and carry the old H3 as a get me home spare in case it blows. The pattern is a little tighter than I like but is much better than some of the after market stuff out there, although the new polisport has had some good reports. I intend to get a later SM or E light when I find one cheap enough on ebay, I also want to retain the rubber strap mounting not have to use the metal brackets as on the S.
This is useful http://www.bri-lux.com/auto-1.htm
This is what mine looked like before I opened it up a little
  • ruddell07
Posted 12 November 2008 - 01:55 PM
Ok, thanks for the tips. Noble, thanks for the correction. The above photo looks almost like it, with two exceptions: the back of the lense is stamped 12v 35w, and the way the bulb and harness is held to the lense is different. It's basically got three prongs and a push and turn set up, like some automotive styles. Sorry I don't have pix of my own to post. Regardless, it looks like I'll be getting out the soldering iron, butt connectors, bailing wire, and duct tape to rig something up. Anybody know how high I can go with wattage?
  • KAW450F
Posted 12 November 2008 - 01:56 PM
heres a link to how to convert stock H3 E/K bulbs to standard H3C Bulbs hope this Helps :thumbsup:
http://www.lexls.com...conversion.html
http://cgi.ebay.com/...sQ5fAccessories
you can get a H3 bulb at any autozone in the trailer sec as a replacemnet bulbs for ??? got 1 there for $4 or 5 dollars they come in 55 & 100w with a glass lense and on ebay theres 55 and 70w H3's :ride:
  • Devondan
Posted 12 November 2008 - 02:38 PM
You do have to watch the distance of the filament from the reflector. It is important for beam shape. I installed the H6m because I wanted a twin filament but if you are not bothered then the H3 will do fine, go for the PIAA 55w the stator can easily cope, it has a 150w output. Is your lens/reflector glass? if its plastic I guess it might over heat?
Dan
Dan
  • ruddell07
Posted 12 November 2008 - 03:12 PM
Thanks for all the replies!
  • bill1960
Posted 12 November 2008 - 08:09 PM
does your bulb look like this ?
and your lens like this ?
if so, then you probably have a plastic lens cover that will overheat if you adapt a decent bulb to fit
I did a similar mod to the one here, using a new lens from baja designs and a 80/80W PIAA bulb. Also wired in a relay and heavier ground and power wires.
http://www.thumperta...hlight=karmolis
  • GreenHornet450
Posted 13 November 2008 - 07:28 AM
I installed a PIAA H4 "Extreme White Plus" 4000 Kelvin-12v/60/55W=110/100W. Meaning the bulb's Candle Watts are equivalent to 110/100W. I was thinking of using the H4 Kelvin 3800Low Beam-5800High Beam-12v/60/55W=135/125W, but I was unsure if it would be to hot for the housing. There is a more Notably Brighter & MORE FOCUSED BEAM.
  • ruddell07
Posted 13 November 2008 - 09:16 AM
Bill 1960, that's it! Last night I ghetto wired a 55w H3 bulb into it and ran it for 5 minutes in the garage. Quite a bit brighter than the old stock one but now you have me concerned about overheating the plastic lense. Thanks for the link to your mod!
  • Devondan
Posted 13 November 2008 - 12:13 PM
Thats the H6m (which I fonverted to) not the H3c. My E light (photo posted earlier) has a glass reflector and lens. If it plastic I'd run it with the 55w bulb and just keep an eye on it!
Dan
  • bill1960
Posted 13 November 2008 - 05:45 PM
I dont know of anyone actually testing/running a 55W bulb in the plastic lens, mainly because of heat concerns.
If you do run it for a while with no adverse effects, please let us know.
Here in Cambodia, all the Japenese delivery S models have the plastic lens.
Most people cant be bothered with the bajadesigns conversion but would probably go for adapting a 55W bulb if there were no heating issues.
Ultimately, I personally prefer the bajadesigns lens. It has a bigger reflector and 80W bulbs can be run without overtaxing the DRZ stator, but it pays to beef up the wiring as well
  • Devondan
Posted 14 November 2008 - 12:23 AM
I think the new Polisport is getting good reviews and that runs an H4, or at least thats what a recent thread said. I havent been able to confirm that from any other web site yet.
Dan
  • GreenHornet450
Posted 15 November 2008 - 08:08 AM
Here is what the Brightness looks like
1&2 PIAA H4 Low & High Beam
3 is the Stock H4 on High Beam
4 is the Silverstar H4 on High Beam
  • Devondan
Posted 16 November 2008 - 07:41 AM
Hiya
What headlight is the H4 in stock s,sm, e?
Dan
  • GreenHornet450
Posted 16 November 2008 - 11:41 AM
3rd pic from the top is the Stock H4 Bulb on High Beam. Bottom pic is the SilverStar H4 Bulb on High Beam. 1st pic is the PIAA H4 on Low Beam & 2nd from top is the PIAA H4 on High Beam
  • Devondan
Posted 16 November 2008 - 12:09 PM
Yeah I got that!!!! but what headlight unit is the bulb in?!
Dan
  • GreenHornet450
Posted 16 November 2008 - 12:20 PM
Dan
Stock 2008 DRZ SM400 Head Light Assembly
  • Devondan
Posted 16 November 2008 - 02:05 PM
Ah, that would explain the H4, I wonder if I could get one to fit in the E headlight surround/plastic?
Dan
