wr 400 98/99 Rear disc hole alignment
4 replies to this topic
  • KevB
Posted November 10, 2008 - 03:09 PM
Can anyone tell me whether the rear brake disc holes line up between a 98 WR400F and a 99 WR400F
The part numbers are 4MX-2582W-00-00 for the 98 part and 5DH-2582W-00-00 for the 99 part.
I know the diameter is different, but I need to mount a 99 disc on a 98 hub if possible...
Thanks in advance
Kevin
  • KevB
Posted November 12, 2008 - 04:26 AM
An alternative might be a Supermoto disc I guess... anyone know anything useful? I need to grow the disc radius by about 10mm to use the 99 Caliper effectively.
  • seehogs
Posted November 19, 2008 - 08:21 PM
Pretty sure the hubs are different. 95-98 same. 99-2006? same. I have a rear rotor from a 96 yz250 if you need one.
  • KevB
Posted November 21, 2008 - 06:26 AM
Thanks for the reply. I know the hubs have different part numbers (4EW-25311-00-00 vs 5ET-25311-00-00) and I know the rear sprockets are not interchangable.
My problem is that I have a '98 WR400F with a swingarm and rear caliper from a '99 model, so now the rear disc is too small in diameter. I need to find out the answer to the hole-alignment question of the discs so I can work out how to solve the problem.
  • seehogs
Posted November 22, 2008 - 08:28 PM
You will have to run the later hub/wheel with sprocket,wheel spacers and disc. Ck Ebay and maybe you can find all of that
