Finally got an aluminum-framed 450!
18 replies to this topic
  • rdefonce
Posted November 10, 2008 - 09:41 AM
I couldn't wait any longer, so I finally snagged a used '08 450. Have only short ride on it but seems like a lot of fun; this thing is both quicker and lighter than my "Old Blue" '99 400F! (It's got the FMF pipe on it, so I suppose better power than with stock unit)
I will be reviewing jetting threads, etc. to see if I'm close there.
also need to replace chain/sprockets.
Offhand, anyone know the # chain links, and have a sprocket recommendation (I'm looking for durability, but also light weight, if that's possible!)
Posted November 10, 2008 - 09:48 AM
(the '08 450) is both quicker and lighter than my "Old Blue" '99 400F!
Yeah, that would be a contrast, alright :worthy:
The stock chain is 114 long. What kind of riding are you going to do?
  • rdefonce
Posted November 10, 2008 - 12:47 PM
Gray, thanks for info.
I'll be doing more track riding with it than anything else, but also some off-road stuff. I'll mostly use my KTM 200 smudgepot for that though.
These two bikes (200xc-w and 450F) compliment each other nicely; very different animals, each a lot of fun, for different applications!
  • Justin89
Posted November 10, 2008 - 01:40 PM
For track, try a 13/50 sprocket combo. Order either a SUNLINE or TAG. they wear like a steel sprocket but are made out of aluminum. I just got the a SUNLINE/D.i.D combo and race/practice twice a week and it shows very,very little wear. TAG and Pro Taper sprockets also wear very well. Stick away from Renthals...these 450's will chew through them quciker than a pack of tropical fruit bubblicious:banana:
Posted November 10, 2008 - 02:08 PM
Try it with the stock gearing first. Change it if you find yourself between gears too often. I went to a 48/13 on mine so I'd shift less.
  • rdefonce
Posted November 10, 2008 - 02:46 PM
Ha ha, lol, tropical fruit treats for the YZ:-)))
You're using a o-ring chain, right?
thanks for quality sprocket suggestions, I'm going to order some now.
  • Justin89
Posted November 10, 2008 - 07:57 PM
Yep Im using the O-ring. Yea like Gray said, try the stock gearing first and go from there. I use the 50t because I like the extra torquey-ness :worthy:
  • Drfletcherdc
Posted November 10, 2008 - 09:22 PM
RK makes a good chain and I used the stock 49T on mine. I had good luck with the blue Renthal sprocket.
  • rdefonce
Posted November 11, 2008 - 07:24 PM
So grayracer, my 450 has 49/13 . . . I'm assuming that's stock.
Guess your 48 rear sprocket would make it geared just slightly taller, but not much diff than stock.
  • rdefonce
Posted November 11, 2008 - 07:27 PM
Man that sounds like it would look cool, blue! But some of the other guys said Renthal wears fast . . . is the blue one more durable than the others?
Posted November 11, 2008 - 10:03 PM
Yes on all counts.
  • Family Man
Posted November 11, 2008 - 10:21 PM
Ive actually been getting pretty good wear out of the 50 tooth Renthal on my bike with the Regina 0rn6 chain. Seems to me like the Renthal and the Regina chain are about even in the wear department.
Posted November 12, 2008 - 07:44 AM
A chain that stays the right length will extend the life of even a softer sprocket by a very significant amount. :thumbsup:
  • jeepcj776
Posted November 12, 2008 - 07:48 AM
whats the word on protaper spockets good/bad
Looking at refreshing my renthal set
  • Drfletcherdc
Posted November 12, 2008 - 07:57 AM
Never had a problem with wearing out my sprockets. I use an RK xring chain and kept it stock gearing most of the time. I also had a blue 50T Renthal that I used for a specific track. The colored sprockets aren't any more durable than the others. Make sure your chain is the proper tension which will extend the life of the sprocket.
Now they have multi colored sprockets from a variety of manufacturers.
Here's what it looked like:
  • Wyatt
Posted November 13, 2008 - 08:00 AM
Very nice looking bike. I always like the way graphics on the airbox that blend with the # plates look. I could never have any. I shred anything that goes on my airbox to pieces with my boots. I dont know how people keep those looking good.
  • 328somewhere
Posted November 14, 2008 - 10:20 AM
I am a huge fan of the renthal twinring for the 450. it doesnt seem to wear regardless of what chain i have use with it. its not the most blinged out but works great.
  • Justin89
Posted November 14, 2008 - 10:51 AM
From what I've read and heard they wear pretty good. Up there with sunline and TAG:ride:
  • Justin89
Posted November 14, 2008 - 10:52 AM
I've always wanted to try a twinring but they just seem to be pretty pricy:crazy:
  • 5 replies
  • Hot  50 replies
  • On January 15, 2017
  • Hot  38 replies
