RE: Hydraluic Brake switch for 03 WR's
4 replies to this topic
  • Jim_Patterson
Posted January 18, 2003 - 03:30 AM
A comment was made that the new rear Hydraulic brake cylinder for WR's was sealed, and putting a Hyd tailight switch on them was going to be a problem. I looked in some magazines and all the pictures show a banjo bolt being used to attach the front of the rear brake line to the hydraulic cylinder body. It looks like a tight fit but I think the hyd switch will just make it. If the pictures are wrong it will require more work to attach a switch.
  • adamwagar
Posted January 18, 2003 - 03:57 AM
Eline http://www.elineacce...s.com/Index.asp sells the Multi-Sport kit for the YZ450. The switch should be the same as the WR.
  • yamaharichey
Posted January 18, 2003 - 09:30 AM
Last years WR-YZ fit, Baja Designs sells them for $17.00.
  • Jim_Patterson
Posted January 19, 2003 - 04:38 AM
Additional info:
Here are pics of the hyd brake switch, and a YZ 450 hydraulic cylinder which should be identical to the WR450’s. As you can see there is a banjo ring and bolt. The problem is that the switch needs 1 inch of room above the banjo collar. This is going to be very tight. I may even have to lower the hyd cylinder and re-adjust the brake pedal. I have had to do this on another bike I made street legal. This will be the fourth bike I have made street legal including a CR250R. When you have a bike that has a battery the wiring is quite easy, but one post thought there wasn’t a banjo bolt, so that concerned me.
(Hydraulic cylinder pic 1)
http://mywebpages.co...jp/P0001816.jpg
(Hydraulic cylinder pic 2)
http://mywebpages.co...jp/P0001813.jpg
(Hydraulic switch)
http://mywebpages.co...p/hydswitch.jpg
  • HighPlainsWR
Posted January 19, 2003 - 05:29 AM
You are right on about that. My 2 day old 03' WR450 went back to the dealer yesterday. Reason: the second attempt to electric start at home jettisoned the starter button (with spring) across the garage. The dealer put on new a switch from an old TT and it works fine. The plastic pressure tab in the button to keep constant outward pressure on the button snapped. During the fix I talked with the owner about installing the hydraulic switch I ordered from Baja Designs. He mentioned the same issue of clearance. There is a banjo bolt w/ head bolt about 3/4" from the subframe which runs diagonally upward to the left. I'm getting the switch tomorrow UPS, I'll let you guys know how it fits, or doesn't.
