will a 450 crank work in a 400?
3 replies to this topic
  • bluebreadtruck
Posted November 09, 2008 - 05:26 PM
I realize that the 426 and 400 both have the same bore and pistons, with a longer stroke crank on the 450.
what is involved if I want to put a 450 crank and 426(or 450) jug and piston on my 400 bike? thanks!
  • PBDBLUE
Posted November 10, 2008 - 07:33 AM
I don't think so. For one the magneto end of the shaft is totally different. Not sure about the primary gear side. Beyond that I believe the geometry may be different also (width, deck height, etc). The 400/426's share the same basic case but the 450's are different.
  • bluebreadtruck
Posted November 13, 2008 - 08:28 PM
Thanks, i did hear that there was an issue with the counterbalancer?
Has anyone done the swap? I really want to get a 450 crank and an athena 780~ bigbore kit!
  • 123BigcoopDawg576
Posted November 13, 2008 - 08:30 PM
if you took the time to do a search you would find your answer....
but to spell it out no you can not put the 450 crank in your 400
