Teardown bike for new season--what to do
9 replies to this topic
  • gtxkid
Posted November 08, 2008 - 07:33 AM
I want to tear down my 85 hour bike for a new season.
What all do you guy's do.
Is it cheeper to buy seal and bearing kits.
Should i do just the wheel bearings
New plastic and grafic's kit--Tire's--grips--exc. are all standard stuff
Motor new chain----rings----set valve lash.
Pack the pipe
Suspention rebuild ( Has already been revalved )
I need some more idea's
  • hondacrf250rrr
Posted November 08, 2008 - 07:42 AM
powder coat ur frame
  • DBMX 925
Posted November 08, 2008 - 07:44 AM
Huh?????????
  • rexbond007
Posted November 08, 2008 - 08:00 AM
repack all bearings,singarm, stearing head,forks-oil change, check valves, and you got the rest.
  • hondacrf250rrr
Posted November 08, 2008 - 08:01 AM
powder coat its like paint kinda but its stronger
  • ryan2214
Posted November 08, 2008 - 08:03 AM
How much does it typically cost to powder coat a bike?
  • hondacrf250rrr
Posted November 08, 2008 - 08:10 AM
depends like 250 depending on what u get done
  • gtxkid
Posted November 08, 2008 - 09:37 AM
I could have it powercoated, i know a guy that will do it for me.
What color and why do you do it.
Is it just for looks
  • Two-Six
Posted November 08, 2008 - 09:41 AM
I doing to same thing getting ready for Mini O's. I am getting my suspension redone, new tires, plastic graphics, greasing all the bearings, and the motor is fresh, I won't mess with it until christmas.
  • motox88
Posted November 09, 2008 - 06:12 PM
ditto...
all bearings.
Fork service - replace dust seal/fork seal. new oil.
Shock service - New oil, proper nitrogen pressure, and seal.
Take the opportunity while these are out of the bike to put in the right size springs is necessary
Check your valves as rex said
Check all engine seals.
Verify that all clutch plates are good and still in spec.
check for any frame cracks or subframe cracks.
Check all bolts and torque/locktite as necessary.
Sprockets
maintain the spokes and balance of the wheels.
bleed the brakes - new fluid!
lube cables.
any jetting of the carb while everything is apart. make sure all jets are clear and just a basic carb clean to verify everything is functional replace any seals if they show signs of wear.
flush cooling system
should keep you bust for a while.
  • Hot  50 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
