Can't remove countershaft sprocket nut???
14 replies to this topic
  • redlineblues
Posted November 07, 2008 - 12:22 PM
Can anyone offer some ideas on how to remove the countershaft sprocket on my 2002 yz426f I have tried a good impact with no succes.
  • Kasjok
Posted November 07, 2008 - 12:25 PM
Ask someone to press down on the rear brake and just use a brute force. A tall leverage helps, too.
  • redlineblues
Posted November 07, 2008 - 12:27 PM
This is a right hand thread ?? correct.
  • Kasjok
Posted November 07, 2008 - 12:40 PM
Turn it CCW, just like a regular nut.
  • hillclimbguy
Posted November 07, 2008 - 12:54 PM
Just remember "righty tighty and lefty loosy" Always works for me.
  • crayztwentyseven
Posted November 07, 2008 - 01:07 PM
That wont work if the nut is a left handed thread.
  • redlineblues
Posted November 07, 2008 - 01:11 PM
Thanks I just got a friend(cost me $20) to come over and sit on the bike with the brake on and try it again.
  • blueshopsuper
Posted November 07, 2008 - 01:15 PM
Next time place your right foot on the brake and lean over the bike with a breaker bar. When you loosen the nut you will be pulling the bike against yourself so it gives you more leverage. BSS
  • dirtsquirt101
Posted November 07, 2008 - 01:17 PM
20 bucks? Hell you could have gone to harbor freight and bought a 1/2" air impact. Granted it would have probably only worked for a week.:worthy:
Posted November 07, 2008 - 01:38 PM
First, they aren't left hand threaded.
Second, the next time this come up, do it the easy way:
With the chain still in place, lay a sturdy board or a hammer handle across the swing arm, through the spokes, as close to the rim as possible. Then crank the nut off. No problem.
Alternatively, you can run the handle of a breaker bar through a hole in the rear sprocket, again, as close to the outer edge as you can get.
  • RJB
Posted November 07, 2008 - 08:47 PM
I'm with Gray on this one. Had a buddy who could not budge his until the wheel was locked in place using said method - he'd tried everything. Came off easy as this way
  • redlineblues
Posted November 08, 2008 - 10:03 AM
thanks guys I will be trying this method today and will let you know how we make out.
  • 328somewhere
Posted November 12, 2008 - 06:05 PM
I always put it in the top gear. stand on the brake, lean over with a breaker bar or impact. hasnt failed yet.
  • Matt_W
Posted November 13, 2008 - 06:52 AM
Do yourself a favor and buy yourself a good clutch/flywheel holder tool. Not only will you eventually need this to remove the clutch or flywheel, it also works well to hold the coutershaft sprocket while spinning the nut off. You can never have too many specialty tools, and I found this tool comes in handy on a variety of applications :thumbsup:
http://www.motionpro...h_holding_tool/
  • matt4x4
Posted November 13, 2008 - 12:39 PM
nice "FRIEND" to charge you 20 - I know times are tough but.... get anything else for that?
  • 0 replies
  • Hot  50 replies
  • Hot  28 replies
