Clutch Basket Groooved to He!!, Need Advice
7 replies to this topic
  • HONDA NO MORE
Posted November 06, 2008 - 08:23 PM
So I got quite a bit of sand my motor at the dunes last month. Split the cases, cleaned everything, replaced bearings. Bike runs perfect now, but the sand did a number on the fingers on my clutch basket. Now the clutch won't fully disengage.
What years of clutch baskets are interchangable with an 06 YZ450? I will be selling this bike in the near future, so I don't want to dump any more money on this than I have to. Does anyone have a good used one that they would sell me? Also if I go with a Hinson, do I have to reuse the gears from the stock unit? How do the gears come off of the stock unit and go onto the aftermarket basket?
Thanks,
Posted November 06, 2008 - 09:16 PM
As far as OEM, '05-'07 are the same. '04 and earlier has a different gear, but they use the same aftermarket basket, in case you run across one.
Aftermarket baskets require that you drill off the rivets and press out the auxiliary drive gear from the original, but it's not so hard to do.
  • crayztwentyseven
Posted November 06, 2008 - 10:28 PM
I did this also, I bought a hinson clutch basket fom a guy that said it was for an 03 yzf, I just put the gear from my 07 on it an everthing fits right up. Make sure to put red loctite on the new gear bolts, it would be a bad day if one backed off while riding.
  • HONDA NO MORE
Posted November 07, 2008 - 07:52 PM
Does this include the 426's and 400's as well, or am I limited to the 450's??
Posted November 07, 2008 - 09:28 PM
In double checking, it seems that only the '04-'08 use the same aftermarket basket. The '04 complete OEM basket/gear does have a different driven gear, also, as does the '08. The '08 is the same number of teeth, but the '08 primary gears were altered to reduce backlash and rattle.
  • gtxkid
Posted November 08, 2008 - 07:14 AM
Do not waist money
Put a Rekluse in if you can aford it
  • Family Man
Posted January 28, 2009 - 05:28 PM
Does the hinson come with the gear pressed in on some models or do you press it in on all of them for the yz450f? If they do come with a gear can the hinson gear be pressed out?
  • Kent Rathgeber
Posted January 28, 2009 - 05:39 PM
As far as I've heard, only one aftermarket basket comes with the gear, and the name escapes me now (of course :banana:)
I have read that if you buy a Barnett basket and send your old one to them, they will exchange the gear to the new basket for a small dollar amount. I don't know if this is accurate, nor do I know what the cost over and above the basket would be.
  • 9 replies
  • 0 replies
  • On January 15, 2017
