Suspension
4 replies to this topic
  • redrider650r
Posted January 17, 2003 - 05:54 AM
Hey guys,
I will be taking the suspension off of my BRP to take it in to Precision Concepts on Tuesday(most likely). What is the easiest way to get the rear shock off? I also have to change out the triple clamps(that should be pretty easy). thanks in advance.
  • jaybert600
Posted January 17, 2003 - 07:14 AM
Just remove seat, muffler, subframe, and shock.
  • Moredesert
Posted January 17, 2003 - 02:38 PM
I need to send mine in to Precision Concepts as soon as I get some $$$. They did a great job the Blacks Race bike we raced in the Baja 1000. Let us know how it rides when you get it back.
  • FooBarr
Posted January 17, 2003 - 06:00 PM
-place bike on center stand and get rear wheel off the ground
-remove seat
-loosen airbox snorkel clamp
-remove top subframe bolt
-loosen lower subframe bolts
-loosen/disconnect some wires
-gently push sub frame back and down while keeping an eye on the wires
-unbolt bottom shock bolt
unbolt top shock bolt and pull out
  • qadsan
Posted January 17, 2003 - 06:18 PM
Once you get the routine down, it only takes 15 minutes to remove the entire subframe :)
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  186 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
  • 4 replies
