2007 450 rear brake
9 replies to this topic
  • FENKER
Posted November 06, 2008 - 05:09 PM
popped the tube fixed it put it back in and my rear brake isnt really working. its all lined up but i have to push really hadr to stop it. anyone know?
  • smithjeb
Posted November 06, 2008 - 05:21 PM
It will. Pump the pedal a few times - make sure pads are seated.
Posted November 06, 2008 - 09:01 PM
The pedal feel is normal, but the effort needed to stop is higher than normal? Sounds like you contaminated the pads or rotor with something. What did you use as a tire lube?
  • FENKER
Posted November 08, 2008 - 11:17 AM
tire lube? i dont use anything
  • desert-rat660
Posted November 08, 2008 - 12:02 PM
maybe u twisted the brake hose
  • FENKER
Posted November 08, 2008 - 12:32 PM
how woould i do that? i left the brake in its place
  • desert-rat660
Posted November 09, 2008 - 09:25 AM
just a thought
  • Dp2boy
Posted November 11, 2008 - 04:24 PM
Gray, I'm assuming changing pads will fix the contaminated pad problem but what do you do if the rotor is contaminated ?
Posted November 11, 2008 - 04:36 PM
Clean it with carb cleaner, rough up the surface with some 280 grit, and clean it again with an automotive brake parts cleaner.
  • yamaha542
Posted November 11, 2008 - 10:59 PM
check the slave cylinder for grooves sometimes if you compress the slave cylinder it will catch a groove and stick, making it hard to stop, does it drag more too?
  • Hot  28 replies
  • 9 replies
  • Hot  47 replies
  • 0 reviews
