So cal desert riding gearing
6 replies to this topic
  • M0SSLAGER
Posted November 01, 2008 - 05:30 PM
Hey guys, curious to see what gearing everyones running that rides in the open deserts of So Cal., such as Ocotillo Wells, Stoddard Valley. I ride a YZ426 and need to change it up as the previous owner had it geared for Glamis.
Posted November 01, 2008 - 06:32 PM
I run my '06 with either stock, or one tooth higher than stock gearing. On your 426, that would be 49/14, or 48/14. There are occasions when I'd like one more tooth off, but they are fairly rare for me. Not so much my son, however. He'd probably like it another notch up.
  • jho410
Posted November 01, 2008 - 07:39 PM
What Gray suggests is about right. It really depends on whether you are going to ride rocky, technical uphills. If so, I would remove a tooth or two from the rear. If not, I would consider adding a tooth to the counter sprocket. When we ride Baja for fun, we run this gearing and it is about perfect.
  • M0SSLAGER
Posted November 01, 2008 - 09:13 PM
Thanx guys. Think I'll pick up a new rear tomorrow
  • M0SSLAGER
Posted November 05, 2008 - 12:59 AM
Hey guys I found a 14 front in my toolbox... what should I expect different on my top end if I go from my 13/50 setup to a 14/50?
Posted November 05, 2008 - 06:26 AM
About 6-7 mph in 5th. 50/14 is still one tooth lower than stock, but it will be way better than what you have. If it was me, I'd go get a 48 for the rear to go with it.
  • M0SSLAGER
Posted November 05, 2008 - 08:15 AM
thanx Gray
  • Hot  50 replies
  • Hot  36 replies
  • 10 replies
  • On January 15, 2017
