1976 MR 250 Elsinore
Posted 28 October 2008 - 05:28 AM
Posted 28 October 2008 - 05:36 AM
Posted 28 October 2008 - 06:15 AM
wonder of these shocks would be any good, seem pricey to me...
http://www.denniskir...309&mmyId=10926
Posted 30 October 2008 - 06:43 PM
Posted 31 October 2008 - 05:04 AM
Posted 31 October 2008 - 05:45 AM
Posted 31 October 2008 - 07:33 AM
Motosprtman said:
Your bike looks great:thumbsup:
How much work to get it to look like that?
Posted 31 October 2008 - 11:49 AM
Posted 31 October 2008 - 04:58 PM
Posted 31 October 2008 - 06:09 PM
dumbdotdog said:
Is it just those type of shocks that are rebuildable or can most twin rear shocks be rebuilt?
Posted 31 October 2008 - 06:31 PM
MEANDMYDRZ said:
Just the CR, MR, aluminum body are. MT, XL steel body are not rebuildable-they dont come apart. 78 cr250 gas shocks arent rebuildable. I dont know about other makes/models, but could tell by looking at them after the spring was removed. If there is a threaded cap where the shaft passes into the body then its rebuildable/re-fillable.
Posted 31 October 2008 - 06:39 PM
dumbdotdog said:
I think I'm out of luck, thanks for the info:thumbsup:
Posted 01 November 2008 - 07:25 AM
Posted 23 January 2009 - 08:14 PM
Posted 23 January 2009 - 11:04 PM
I've been looking for awhile now but since they were only made for one year they're hard to come by.
I did see one the other day on CL. but it was to much work to try and bring the ole gal back to life.
It looks like you got a good one motosprtman.
Pop's
Posted 24 January 2009 - 10:39 AM
I'm trying to get an idea of what final ratio to start off with on the '77 motor. I won't need it to do the trials-bike thing like the '75, but I'd like it low enough to not need too much clutch slipping in tight woods.
Ray
Posted 24 January 2009 - 12:23 PM
Posted 24 January 2009 - 12:55 PM
I'm almost done with the MT/MR hybrid pipe experiment - it wan't quite as easy as I thought it would be, but at least now I know what's inside the MT125 and MR175 pipes (nothing impressive, believe me). I'll post back when it's done.
You don't happen to have a '77 MR175 mainshaft and countershaft 1st gear, do you? When my '75 gearbox finally gives out I'm going to try putting a mix-and-match 6-speed gearbox in it, using CR/MR/MT gears.
Sorry about hijacking this thread.
Ray
