de-octopus mod?
1 reply to this topic
  • WR_Man
Posted June 24, 2002 - 08:14 PM
what does this mod do you do it?
  • The_Missile
Posted June 25, 2002 - 01:29 AM
If you have a 98 or 99 you can do it. Otherwise you need to do the Air Cut Valve mod.
Deoctopuss.....the octopuss is the thing which sits on the left side of the carb...a metal body with lots of pipes, tubes coming out of it from all directios. Pull it off including all the pipes. Plug the hot start rubber hose into the brass pipe at the lower front left of the carb. Block off the other brass pipe openings.
Change the starter jet to a 60 (check that in the archives/tech section)
You are done.
Rejet as necessary.
