EKT??????
4 replies to this topic
  • Guest_Guest_*
Posted February 10, 2001 - 11:30 AM
I ordered the ekp needle over the phone and the salesman must have heard ekt-which is what I ended up with. Where does this needle stand compared to ekp?
  • Andrew_in_OZ
Posted February 10, 2001 - 11:49 AM
The EKT is slightly leaner in the straight part of the needle affecting closed to 1/4 throttle,after 1/4 throttle both needles are the same.If you use a #48 pilot jet there should be no problem.
Andrew
"00"WR400
  • James_Dean
Posted February 10, 2001 - 12:43 PM
Sounds very lean just off idle. See if it hesitates right from the crack of the throttle. Roll it open very slowly to check.
You may need it in clip #4 and with a #48 1 turn out as Andrew said.
The needles in order are - EKM EKN EKP EKQ EKR EKS EKT from rich to lean.
  • Taffy
Posted February 11, 2001 - 02:19 PM
could be the needle you've always wanted jd!!!
Taffy
  • Taffy
Posted February 26, 2001 - 02:08 PM
chris
mail me please
Taffy
