JD Kit and 2.75mm
3 replies to this topic
  • motoscotty
Posted October 22, 2008 - 07:51 PM
JD recomends 2.75mm between the linkage and the the black plastic on the ac pump linkage for tuning the pump.Has anyone ever tried or used this.I would always back it off til there is no play and go 1/2 turn past that.The 2.75 is way past that half turn.I will report back with my test results.This is on a 08 450.
  • William1
Posted October 23, 2008 - 02:37 AM
I only use numbers like this as a starting point. I set the AP by visually confirming the squirt just misses the slide.
  • timoyz1
Posted October 23, 2008 - 06:30 AM
Ditto. While sub-frame and shock is off, it is really easy to visually check.
  • Charles De Mar
Posted October 23, 2008 - 06:35 AM
When I bought my Quickshot2 they had a spacer provided to set mine. Mine just misses the slide too:thumbsup:
