Piston, cam, bigbore for 400?
5 replies to this topic
  • bluebreadtruck
Posted October 22, 2008 - 05:21 PM
I have my wr timed to yz specs and love the top end power, however i would love to get some more mid/low power without loosing the top.
With my old 4 strokes, i would always add a highcompression piston and a cam, and maby bore it.
My question is with the 400, what is stock compression, and can i run a higher compression piston with pump gas?
would an aftermarkert cam set like a hotcam, etc really make a difference in power?
Do they make a big bore for an older 400 like mine?Is it possible to swap in a newer 450 cyl? thanks alot guys....been riding the bike stock and love it, but always looking for more power....ive been riding with streetbikes lol.
  • tcmII
Posted October 23, 2008 - 04:02 PM
check out this link. They offer a 400 to 426 with a bore change or 400 to 440 option with a bore and stroke change.
I was looking into this and didn't finish the research. I was thinking that if you only wanted to go to 426 you could buy a 426 jug and and a proper oversize piston for the 400, you might be able to do this without the crank/rod change. Maybe some else knows if the piston is availabe. This could save some cash.
  • bluebreadtruck
Posted October 23, 2008 - 05:17 PM
thanks. could you use a 450 jug, piston and crank in a 400?
  • Oasis_Flame
Posted October 24, 2008 - 01:08 PM
Yes you can because I've done it 4yrs and 5000 miles ago. Wiseco carries the piston 13.5 to 1. Stock is 12.5 to 1. I'm using a stock 400 head, crank and carb. Runs on pump gas all day long and man is it tons more powerful. I bought a stock WR 426 jug off of E-bay for $50.00 in great shape no boring needed. Jetting was nothing to figure out.
  • bluebreadtruck
Posted October 26, 2008 - 04:57 AM
oh, so wiseco makes a 400 piston that will fit in the 426 bore sleeve? im a wiseco dealer so yay!
  • bluebreadtruck
Posted October 26, 2008 - 05:08 AM
OK, i just checked out my wiseco catalog
I see they make a 13.5:1 400 piston and 426 piston.
Could I buy a 426 or 450 jug(same 95mm bore), buy the correct piston and bolt it up?
Do all years use the same wrist pin size? I heard there is a cutoff year, but wanted to verify.
can you run 13.5:1 on premium?
