Carb bowl screws
9 replies to this topic
  • c9buff
Posted October 22, 2008 - 03:58 AM
I took the bowl off the carb and in the process mangled the heads on the phillips head screws. Seems everyone has this problem that I talked to.
Anyone know if there are replacements that would do a better job.
buff
  • matt4x4
Posted October 22, 2008 - 04:28 AM
you need a special japanese Spec#2 philips screwdriver for them!
(No, I'm not pulling your leg...)
http://www.amessuppl...=DE&fid=1404070
  • buggs bunny
Posted October 22, 2008 - 07:05 AM
just take your mangled screw to the local hadrware store or motor cycle shop and match the thread size and leangth with allen head screws.they take alot more abuse than a phillip head screw.
  • drtbk4ever
Posted October 22, 2008 - 07:32 AM
The allen head screws you find on the top of the carb are a perfect replacement for those brass like screws. So I ordered 4 of those allen head screws from my dealer. I only got 3 so I notched the remaining phillips type screw with a hacksaw so at least I can get it on and off with a slotted screw driver.
  • 123BigcoopDawg576
Posted October 22, 2008 - 07:45 AM
This is the best way to fix the problem....however yamaha finally figured it out with their 07+ bikes as they already come with allen bolts:banana:
  • Charles De Mar
Posted October 22, 2008 - 08:03 AM
I always replace the phillips with allen button tops. On everything. If I unscrew it with a Philips I replace it. ALWAYS!
  • c9buff
Posted October 22, 2008 - 06:44 PM
Hey drtbk,
Are those the allens that hold the top cover on that gives access to the needle?
Thanks for the info,
buff
  • 123BigcoopDawg576
Posted October 22, 2008 - 07:31 PM
Hey drtbk,
buff
those would be the ones!
  • drtbk4ever
Posted October 23, 2008 - 06:44 AM
Yep, those are the ones. I couldn't find any at the hardware store nor the bolt supply warehouse. That is why I had to order them from Yamaha.
  • 123BigcoopDawg576
Posted October 23, 2008 - 07:15 AM
i think my dad found them at home depot but none the less ordering the oem ones are still cheap and well worth it:ride:
