Easy water pump and countershaft seal replacement!
46 replies to this topic
  • Strattos
Posted April 22, 2011 - 03:54 PM
Grayracer - thanks for the tips. Sorry, didn't mean to hijack the thread, but the OP went straight onto countershaft seal removal in the opening page.
066logger - advice on removing the collar was a couple of pages earlier. Think it was tribalbc who mentioned removing the seal makes the collar pop out as well, or something like that. Might have to go back a couple of pages.
Just picked up parts this morning. Glad they had them in stock, as got a ride this afternoon. Thanks to all for their help.
  • WRF Woods Weapon
Posted April 22, 2011 - 04:14 PM
Nice do it yourself tips with pix, yet to put that 1000km on the clock.
Posted April 22, 2011 - 04:46 PM
Use a plastic mallet, or place a block of wood over the end of the output shaft and give it a little rap or two inward to break the bond the O-ring has on the collar. Then grab it with a pair of pliers and twist and wiggle it off.
  • 066logger
Posted April 23, 2011 - 08:40 AM
sweet. i just didnt want to get too agressive till i was exactly sure what to do :thumbsup:
  • 066logger
Posted April 23, 2011 - 11:58 AM
yes finally got it!!! after tapping on the shaft for a while and using some pb blaster on it and still no luck i noticed the bushing has groves on the backside. so i bent a piece of wire just right to catch the groves and pulled it right out :thumbsup::banana:
  • juntini
Posted April 29, 2011 - 03:49 PM
I have a question. In the manual it states to put some lithium based grease on the new seal prior to installing. Question is, do you put grease on the outer edge of the seal ( as indicated in the manual) and on the inner edge that goes against the impeller shaft?
  • resinlips
Posted May 01, 2011 - 02:00 PM
I just replaced my outer seal and it did the trick. After buttoning it back up, re-filling the coolant, and running the bike I found a pin on the ground.
I don't see any reason not to run the bike with one missing dowel on the pump cover. With one pin in place and the 4 bolts, there is no way the pump cover is going anywhere. I'm feeling lazy and not motivated to drain the coolant again.
Any thoughts?
