Softer ignition curve for 2008 YZ450
11 replies to this topic
  • pobit
Posted October 19, 2008 - 07:05 PM
I use my 08 YZ450 for racing enduros and I am looking for a CDI with a softer power curve. Vortex makes a programable ignition but at $500.00 it's over my
pay scale. Is there a stock Yamaha box that will plug in and give a softer curve? Thanks, Dave
  • DPW
Posted October 20, 2008 - 02:23 AM
have you thought about a heavier flywheel?
LIKE THIS
  • pobit
Posted October 20, 2008 - 06:08 AM
Thanks for the link. I may add a flywheel weight after the ignition but the problem I have is the advance is too quick at off idle giving the bike a hit. If the spark were retarded at off idle, it would smooth this area out and prevent wheel spin. Does anyone know if the 07 YZ450 CDI has a softer power curve at off idle? I can buy new take off's for $50.00
Thanks, Dave
  • Kasjok
Posted October 20, 2008 - 06:43 AM
A heavier flywheel will do just what you need!
  • KAS
Posted October 20, 2008 - 08:38 AM
The '07 ignition wouldn't make it any smoother.
What about using a WR ignition?
  • SUnruh
Posted October 20, 2008 - 10:13 AM
talk with jessie at williamsmotorwerx about the msd ignition.
Posted October 20, 2008 - 11:13 AM
WR450 ignition systems are incompatible with the YZ electricals.
I believe Graves makes a programmable ignition for the YZ450. It will likely be in the same general price bracket as the other aftermarket ignitions, though.
  • JSanfilippo
Posted October 20, 2008 - 09:04 PM
I'm not a fan.
If I had $500 burning a hole in my pocket I'd get a vortex ignition and set it to 11 :D. With the stock WR ignition from about 10% to 100% throttle the response is great but from 1%-9% its kinda soft. I know yamaha did that for tractability reasons and I appreciate it in tighter terrain but in the open its kind of annoying.
  • KAS
Posted October 20, 2008 - 09:42 PM
Which is exactly what the OP is wanting.
Posted October 21, 2008 - 05:20 AM
Maybe, but unless you rewire the stator and the rest of the bike, the WR CDI simply won't work.
  • Thumper_Bloke
Posted October 21, 2008 - 08:51 AM
How about Dynatek? I have one on my WR450 and its extremely adjustable.
Not sure if they have the 2008 YZ, you may have to call to find out.
http://www.dynaonlin...es/fs_ignition/
  • projected
Posted December 04, 2008 - 05:55 PM
G2 throttle cam? I don't have one but have read many good things about it, at $100 it's worth a try.
Lot's of info here:
http://ktmtalk.com/i...howtopic=160166
Motocross
  • Hot  491 replies
  • Hot  50 replies
  • Hot  113 replies
