Oil drain bolt, possibly over-torqued...
3 replies to this topic
  • DangerRanger245
Posted October 19, 2008 - 05:56 PM
Today while changing my oil on my 06 450f I did a dumb thing.
I had my torque wrench set to 20 NM, tightened up the two lower drain bolts, and went to the third one on the oil filter cover, and after an 1/8 to a 1/4 of a turn after it got stiff, I realized i still had the torque wrench on the wrong setting.
I screwed it out, and screwed it back in by hand, and torqued it down to spec. It seemed to grab just fine.
So I overtorqued it by maybe a 1/4 turn, it doesnt leak even after a quick ride around the block, it should be fine, right?
  • KWJams
Posted October 19, 2008 - 05:59 PM
The risk is to pull the threads out of the hole. Sounds like you caught it in time and should be ok.
  • DangerRanger245
Posted October 19, 2008 - 06:02 PM
Yeah I know that one. I looked closely at the bolt when I pulled it, and didnt see any fragments of threads.
I'm just paranoid, this is the first real possible issue on this bike.
  • Justin89
Posted October 19, 2008 - 07:17 PM
I would much rather have it be the oil filter bold than the drain bolt. When I first bought one of my yzfs, the magnetic drain bolt was stripped and ended up breaking inside the case...that was fun:banghead: Anyways, I think you will be fine
  • 0 replies
  • Hot  50 replies
  • Hot  28 replies
  • 5 replies
