yz426 gearshift keeps coming loose
2 replies to this topic
  • laserracer
Posted October 18, 2008 - 11:11 AM
Man im getting sick of tightening up my shift lever ,ive even ground out the slot in the shifter so it can clamp tighter to the shaft ,and put a longer bolt with a backup nut on the end to stop it coming loose ,so anyone got any tips or should i just look at getting an aftermarket shifter; i can do it up tight then after 1 days ride it is loose on the shaft again
  • laserracer
Posted October 18, 2008 - 03:42 PM
shit snaped another bolt off trying to tighten it up can you loctight the gearshift to the shaft ?? then bolt it up
  • laserracer
Posted October 18, 2008 - 05:34 PM
OK now have it sorted... on advice from www.kiwibiker.co.nz i checked the output shaft theres a groove that runs around the shaft that the gear shift bolt passes through and this has worn will redrill gear shift lever and fit bigger bolt :D
  • Hot  113 replies
  • On January 15, 2017
  • Hot  36 replies
  • Hot  50 replies
