Wheels?
2 replies to this topic
  • KOZ97
Posted 10 January 2003 - 06:13 PM
Will a set of wheels front and back, from a 2001 cr 125 fit my '03 crf? I found a set. Wanted to be sure before I did anything stupid. Like find out the axle is to small. :)
  • wingman111
Posted 11 January 2003 - 05:59 AM
Dear KOZ97
The wheels from any CR from 95 on will fit in the front you must use the left hand wheel spacer from your CRF to make it fit 02 and 03 bikes though.The rear wheels that will fit are 2000 and on they will bolt right up but although the rear disc brake will work and is the same outside diameter on the 02 and 03 the ID where the bad makes contact with the disc is somewhat smaller on 00 and 01's likes is said it will work you can use a 02,03 disc but you must drill out the bolt mounting holes to suit the larger diameter shouldered bolts on these earlier wheels.If anyone is interested in a disc that is already modified I have one that I would like to sell.I used it with a 2000 wheel that I used until I traded it for an 02 wheel. The CR125 rim is a 185 width rim and the 250 is a 215 that is that it will be narrower on the 125 you can use it but it will make the profile of the tire narrower and taller hope this helps.Cheers
  • KOZ97
Posted 11 January 2003 - 06:51 AM
Thanks Wingman. This helps I'm gonna stick with finding the set for a crf, for simplicity, Thanks again.
