2002 wr426 running too lean
4 replies to this topic
  • beyaranch
Posted June 21, 2002 - 01:26 PM
i recently opened my exhuast pipe and taken off the lid on the airbox. i am assuming that it will run too lean. what do you suggest to solve the problem? :)
  • StreetMoto
Posted June 21, 2002 - 02:56 PM
I have a 2002 and have done all the free mods including the BK. My jetting is stock except for droping the needle one clip position. I dont think mine is running too lean right now. Its really running good. Im not touching the carb until I another 426 that is making better power.
Id say leave it as is and rock on!
  • TAC
Posted June 21, 2002 - 03:47 PM
I have done the same mods and had the same questions after riding and reading my spark plug it has actually seemed to richen the mixture up not leaned it out. Now that you are able to get the exhaust out of the bike you are not leaning out the fresh charge into the cylinder. I am guessing that you have already cut the throttl stop?
  • Taffy
Posted June 21, 2002 - 10:33 PM
they come about 10 too rich and you need about 10 for the pipe so all in all you're about there. you may have a slight problem in the mid range so in that case i would try the needle. up one or down one just to see.
this is a case of don't fix it less it's broke.
Taffy
  • blue_beast_wins
Posted June 22, 2002 - 11:21 PM
Usually too rich.
[ June 23, 2002: Message edited by: blue beast wins ]
