426 specs VS 400 specs
1 reply to this topic
  • oddball
Posted June 21, 2002 - 08:14 AM
I have used this site and found a lot of info for setting up a WR400, but little set up for my 426. Now maybe I just need to look harder, but my question is this.
I see most people are running around a 158MJ and running a DMM needle, on a WR400. My 2002 WR426 came stock with a 165MJ and a DRR needle. Service manual does not list a DMM needle for the 426. Do I want to go with 400 specs, or do I have a different beast?
The reason for the quest is a choking in nuetral, when snaping from idle to 3/4 throttle. I have removed the sprak arrestor, ripped off the air box top, and removed the throttle stop. The bike is a monster when just running from idle to half throtle.
I would rather be looking at it, then looking for it.
Jason
  • mcarp
Posted June 21, 2002 - 10:44 AM
I would bet the jetting should be very similar given similar mods.
But I'm not sure I agree most people are running the jetting you mentioned. It's all over the board..
