Does anybody have any tips for cutting holes in the ends of your handgrips to mount Acerbis lever guards? I've done it a few times on different bikes, and never come up with a clean way. Maybe stick a dowel in the grip and use a drill with a hole saw bit? I just got some new grips, and I'd like to do a cleaner job this time. Thanks.
Handgrip Hole Cutting Tips?
Started by berkeman, Jan 10 2003 06:41 AM
6 replies to this topic
Posted 10 January 2003 - 06:41 AM
Posted 10 January 2003 - 06:51 AM
use a hammer. A mallet f some sort. It works for my bmx bikes. Just put the grip on and the keep hitting the grip until the hole wears through.
Posted 10 January 2003 - 07:17 AM
I use a piece of 3/4" copper tubing. Use a tubing cutter to cut both ends of the tubing - this makes a nice "cutting" edge on the tubing without it being too sharp to handle. Anyway, then just slide one of the grips over the end of the tubing and use a rubber mallet to tap on the end of the grip. The tubing will cut a nice, clean, centered hole in the end of the grip. Good luck!
Posted 10 January 2003 - 10:14 AM
A hand grinder works great! Just grind down to the bars. 5 or 10 seconds per side. Adjust throttle in an 1/8" or so and install your gaurds.
Randy
Randy
Posted 10 January 2003 - 10:38 AM
This is where LOOPOUT could use his Dremel he got for Christmas. Just ask him, I'll bet he will come by and do it!!
