Bent Rim. How bent is too bent? Pic
11 replies to this topic
  • broccoli2
Posted October 11, 2008 - 06:18 PM
So I bent my 08 WR450 front rim today and was wondering what all your opinions are?
I ride trails and desert
I never even slowed down and road it the rest of the day. I knew I hit it pretty hard but didn't think I bent it and didn't check until I got home. This dent is only on one side of the rim..
What do you all think?
Do I need a new rim?
Can it be bent back good enough?
  • 2smokeforlife
Posted October 11, 2008 - 06:22 PM
wouldnt try to bent it back will prob be fine untill u get a new rim, i rode my yz will 2 dings in it for a year almost and it was fine just keep checkin the spokes to see if they are tight
  • brad the best
Posted October 11, 2008 - 10:45 PM
thats fine i had one like that , i just beat the crap out of it with a 3lbs hammer . it went away .
  • DeeCee
Posted October 12, 2008 - 12:25 AM
Is your tyre running true when you spin the wheel ?
If it is not too far out it is probably OK not to worry about it.
You may be able to adjust the true by changing the spoke tension.
  • drumurr
Posted October 12, 2008 - 06:00 AM
smack it with a rubber mallet
  • LILBIT
Posted October 12, 2008 - 06:46 AM
HARD! A few times and you'll be good to go.
  • bfogelma
Posted October 12, 2008 - 07:28 AM
hell as long as its not causing repeating flat tires right?
  • timoyz1
Posted October 12, 2008 - 08:46 AM
Good luck pounding it back. If you have access to a press, that would be easier, if not, ride it like you stole it.:D
  • Fullbore4
Posted October 12, 2008 - 10:21 AM
I used a wood piece and sledge take out dents ....the wood doesn't mark it.....like they say don't force it, just get a bigger hammer:banana:
  • broccoli2
Posted October 12, 2008 - 11:11 AM
Thats what got me into this:bonk:
I road it today.. Ran like normal.. I think I'm just going to leave it alone..
Thanks for the advice
  • WR_Dave
Posted October 12, 2008 - 11:16 AM
I tried to straighten one out a few years ago and had it almost back when I heard a sickening crack and completely broke the rim right across it's width. If the wheel is still true and your not flatting the tire I would just keep riding. My .02 -- WR Dave.
  • Charles De Mar
Posted October 12, 2008 - 12:17 PM
X2 on the press. i had a rim like that and took it to my mechanic who has a press. It came out really straight. My mechanic said don't try to pound it out for fear of making it weaker.
