Dune trip this weekend... Longer Chain?
15 replies to this topic
  • curthall11
Posted October 09, 2008 - 05:45 PM
Hey I am heading to the dune this weekend on a YZ426F with a stock gearing of 14/49 and a 114 link chain. I am going to put a 50 tooth sprocket on the rear. Do I need to extend the chain for the paddle to fit?
Posted October 09, 2008 - 07:36 PM
Possibly.
  • curthall11
Posted October 09, 2008 - 07:58 PM
Well I just got a 120 link chain so I'll just cut it down to length then. Thanks
  • spc mike
Posted October 10, 2008 - 11:56 AM
YES, i just went through this. a 14/49 setup with a 114 link chain and a paddle will not fit without hitting your lower shock linkage. But if you have a longer chain then thats perfect, but i just bought a cheap($12) 13 tooth sprocket (since i will only use it for a limited time and its cheaper than a chain) and i had plenty of slack with a 114 link chain. and not to mention that the extra torque the 13 tooth gives helps in the sand as well! i hope this helps for future reference.:D
  • clutchless
Posted October 10, 2008 - 11:58 AM
yes, spc mike is right.
you really don't want a 14 in the front even with a 50 tooth rear.
13 / 49 is what i ran in glamis last year.
  • xjruss
Posted October 14, 2008 - 10:43 AM
Do you really think it's necessary to gear down? I run 14/48 on my 450 and it's great in the dunes. My 426 is currently at 14/49 but it's got more torque than I know what to do with so it's going to 14/48 as well, maybe even a 47 out back.
  • clutchless
Posted October 14, 2008 - 10:51 AM
depends on your style of riding i guess.
i really like the power of a 13 / 48 in sand, it may be more of a personal thing.
i am also 215 pounds in gear.
  • xjruss
Posted October 14, 2008 - 11:04 AM
Probably so... I guess I just got the impression that the OP was gearing down based on a suggestion rather than personal experience or preference.... but that's probably not the case.
  • clutchless
Posted October 14, 2008 - 11:29 AM
i find that knowing where i am in a gear is really important in sand.
hitting a jump can be deadly if you do it wrong.
i like to carve bowls, roost, and hit 20 foot jumps and step ups.
last thing i want to do in sand is go too big and changing gearing can do that if you aren't paying attention.
Posted October 14, 2008 - 12:10 PM
I run my '06's at 48/13 (one higher than stock) for the desert, including the dunes, and never have a problem in the sand. I have run an '03 with 49/15 (stock is 48/14) and it was fine, too. It's a 450, not a 250.
  • xjruss
Posted October 14, 2008 - 01:11 PM
Sorry guys, I'm tarded... I totally forgot that my 450 was 13/49 in stock form... so I'm running 13/48, not 14/48. I still get the gearing mixed up between the 450 and the 426... anyway, my 426 is 14/49 at the moment and I will be dropping a tooth or two on the rear to spread it out a bit more.
  • husqy360
Posted October 14, 2008 - 03:00 PM
im runing 12 front 49 rear and love the power.
wish i could go faster with this 12 t gear, the power is fainaly amazing.
but a little to slow, 5th fell like 4th.
how can i get the power of the 12 with a 13 t front sprocket?
12 t is only good for small places, the speed just disappear with the 12.
engine feel totaly diffrent like it will rev more in the sand and the powerband will fainely kick.
  • rideawn
Posted October 15, 2008 - 12:32 PM
I run a 50 rear on track and trail and the stock 49 rear in the dunes. No issues with power. 5th can be a little light when climbing long, steep dunes, but 4th offers plenty of speed for me. I'm 190 lbs with gear. I use the same chain in both setups, but switch mud flaps. My dunes mud flap is half the length of normal since the paddle tends to chew it up.
  • tnl
Posted October 15, 2008 - 04:00 PM
Make sure those chain rivets are pressed together properly. Don't skimp with the needle nose pliers.... It costed me big bucks!!!!
  • bansheeater1
Posted October 16, 2008 - 03:59 PM
I've never had to get a longer chain for the dunes. I just throw my paddle on my bike and ride. It never even touches the suspension flap.
  • tnl
Posted October 16, 2008 - 05:51 PM
I've swapped out the front sprocket for more top end but either way the bike has good power anywhere except top gear in the deep bowls.
  • Hot  113 replies
  • Hot  38 replies
  • 5 replies
  • 0 replies
  • On January 15, 2017
