impeller seal replacement tips
2 replies to this topic
  • nashport_native
Posted October 09, 2008 - 04:41 PM
I had a leaking seal on my 99 400, so in the process of trying to remove the impeller from the shaft, the flats twisted off the shaft. :D
so even if you are just changing the seal, I would remove the whole side cover so you can put a wrench on the back side of the shaft (it has 2 flats machined into it for a 13mm wrench)
oh and the impeller shaft carries the same part number from 99-08 on the 400-450 and the yzf450
Posted October 09, 2008 - 04:50 PM
How many times have I warned that this would happen? But somebody comes up and says, "Oh, I took mine off that way and nothin' happened so what's the big deal?" Well, here's an example.
BTW, the wrench flats are for a 12mm wrench.
  • nashport_native
Posted October 09, 2008 - 07:30 PM
oppss, your right gray, it was a 12mm.
guess thats what I get for not looking on here first.
I have changed a few of them on my older cr's without removing the side cover.
either way, local shop had the part, it needed replaced anyway. just thought I would let everyone else know, take the extra half an hour and remove the cover too.
  • Hot  113 replies
  • Hot  50 replies
  • 0 replies
