99/00 stator output
5 replies to this topic
  • LILBIT
Posted October 09, 2008 - 02:46 PM
I searched here and the posts/answers don't agree. Can some one say for certain if the stator output went up to 120w in 2000 or did it wait until the 426. I have a '99 and a '00 stator and although it's been a while since i looked i rememeber the windings looked the same. Also is any one running a HID off a '00 or '01 with stock windings. If i can't run a HID i'll stay with AC and a halogen. Thanks.
  • matt4x4
Posted October 10, 2008 - 09:54 AM
can't guarantee it but my 2000 runs 2x 55W halogens just fine with no signs of power loss - the 98/99 were only 80w and wouldn't suffice with my setup.
not sure if 120W will suffice for a HID though - depending on make you might have to go to 150W
  • LILBIT
Posted October 10, 2008 - 01:23 PM
Thanks for the response. Two 55w huh? I wouldn't know what to do with all that light. I'll try to swap it out this weekend. Still debating floating the ground before i put it in just in case i want to go DC and HID later. Laziness will likely take over. The HIDS don't pull much but volts can't drop to low at idle without a battery or they will flicker or worse just turn off.
  • ncampion
Posted October 11, 2008 - 09:32 AM
You'll need a small battery to run the HID. As you said, the idle voltage will drop and the ballast will turn on and off, ultimately destroying it. A small NiMh pack in the air box works with fine and the HID's only draw 35 watts and work great. Have one on my 98' WR with stock stator.
  • henrics
Posted October 12, 2008 - 01:04 AM
Well the Hid bulbs are 35w but the ballast also draws ~7-8w.
I did use a wr250-426 -01 stator and flywheel + battery on my -06 yz250f. You could run 2xhids but you need to keep the revs up.
There are 21w hids that draws about 26-27w you could use 3 of these instead.It is difference between good hids like Hella,Philips and Osram and the cheadp ones you buy on ebay (chinamade).
http://web.telia.com...Hojen/ljus2.htm
  • LILBIT
Posted October 12, 2008 - 05:24 AM
Thanks for the responses. If i do go HID it would be a single. I'm a little concerned about street use because i dual sport the bike. Some do it any way but i wouldn't if it's massively blinding to oncoming cars.
Popped the cover off yesterday ad threw a jawwed puller on the flywheel. No go-got scared of buggering the crank threads. Done it before with a harmonic balencer puller but i'm scared to screw up the crank threads. Guess i'll order the Yamaha tool next week.
I've read multiple reviews of the cheap HID that Kragen/Checkers sells. Mototrcycle,quad,Rinos, and buggies. Not one major complaint. No doubt not as good as a high end unit but $120 is hard to beat.
