No Spark! Help!
4 replies to this topic
  • fmf-wr
Posted June 20, 2002 - 08:15 AM
I've got a 2001 wr400 i've just done the cam chain and piston and rings put it back together and it will not spark all the wiring seems fine. Any idears
thankz
  • Hick
Posted June 20, 2002 - 08:32 AM
Do you mean it won't start, or that there is no observable spark at the plug??
  • lewichris
Posted June 20, 2002 - 09:00 PM
make sure the coil is getting a good ground on the fraim and make sure the coil wire that is going into the plug connector is connected to the actual plug connector. it can come loose. and if you are dual sported make sure your switch is on.
  • YAMAKAZE
Posted June 21, 2002 - 02:16 AM
Chris.....
Frame...Frame...Frame...
Bonzai :)
  • lewichris
Posted June 21, 2002 - 04:27 AM
lol. I really need to go back to high school
