Roached my motor - Any ideas?
34 replies to this topic
  • tdamore
Posted October 06, 2008 - 10:19 AM
I was riding most of the morning with no signs of trouble. I was cruising along in fourth gear on a long wide road (road to randsburg for those of you in so Cal) when all of a sudden it just died. Went to kick it and the kick starter is locked hard.
Bike just had a fresh oil change before the ride and the coolant level was fine. It may have been running a little lean as I was getting quite a bit of popping on deceleration but it wasn't running hot or boiling over. I drained the oil when I got home, and you can see fine metal particles in the oil. I am hoping that the piston just seized, but I have a feeling it's going to be one of the rod end bearings. Any ideas as to why a motor would just go like that? One thing to note, is that it was blowing a bit of oil out the valve cover breather tube most of the day. I usually change my oil before every ride, so I just figured it was a little overflow.
  • knightsofstevenson
Posted October 06, 2008 - 10:25 AM
Sorry to hear the bad news. Were your valves in spec still??
Posted October 06, 2008 - 10:26 AM
If the abrupt halt was not accompanied by a brief loud clattering, it's probably the big end bearing.
  • tdamore
Posted October 06, 2008 - 10:33 AM
No noise, and I am pretty sure you are correct. Now I just need to decide if I want to tackle this myself or take it to a shop. There seems to be quite a bit of money to be saved by getting the parts online from TT oem vs. the dealer or a shop, but I have not split cases since I did my 1980 yz80 back in 1987 :lame:
Posted October 06, 2008 - 10:59 AM
Only the top end is more complicated. The bottom is just bigger. Download a manual if you don't have one, and go for it.
  • tdamore
Posted October 06, 2008 - 11:26 AM
I think I will, every penny counts these days. Anything to look out for or any tips? special tools needed etc? I am going to start pulling things apart tonight and plan on using zip lock baggies and labels to group assemblies etc.. I am most curious about making sure that I know what to look for so I can make sure it does not happen again.
I really appreciate the help!
  • matt4x4
Posted October 06, 2008 - 11:36 AM
If you're not 100% sure - take LOTS of pics - use paint pens to mark timing gears/chain, gears etc - although once you have a manual - it won't be needed since every gear has a mark that lines up with something.
It's easy - like grey said.
Posted October 06, 2008 - 12:08 PM
The only special tools you can't really do without are a flywheel puller and a #27 Torx bit for the stator plate.
  • tdamore
Posted October 06, 2008 - 07:43 PM
You were right on the money Gray. Seized big end bearing. I also noticed my intake cam looks like the journals got real hot. There is some wear and scorching on them so I will probably need a new head as well :lame:
Posted October 06, 2008 - 08:50 PM
The head can be repaired, believe it or not. Send it to EDCo
Also, critically examine the entire oiling system.
  • 00WR400F
Posted October 07, 2008 - 02:06 PM
exactly, sounds like the oil tube is clogged or the oil pump is to weak to pump oil to the cams.... run clearances on the pump
  • yz480doinwork
Posted October 07, 2008 - 05:27 PM
what ever you do REMEMBER how to put it back together. working at a dealer ship we see a lot of guys that forget how it goes back together so the box it up and bring there mess to us. its a horrible mess for us because every year things change the most of the time goes unknowtised. you sould be fine. im trying to decide if i should do mine myslef or have our michanic do it when i put my stroker in.
  • tdamore
Posted October 07, 2008 - 09:57 PM
I packed up the head today and shipped it off to Mike @ Edco. I am going to wait to see what he says before I make my next move. This is what I am planning:
New piston and rings. Probably do a Wiseco OE replacement.
Cylinder hone.
Hot Rods crank and rod.
New main bearings.
Flush all oil passages\lines and check clearances on pump.
Assuming the only thing wrong with the head is the bearing surface and all the valves are still in spec, I'll probably try to reuse them to keep costs down. I think i can clean up the intake cam and remove the deposited aluminum from the journals.
Posted October 08, 2008 - 05:40 AM
That may not work out so well. If the cam has seized, or tried to, it may have caused the sprocket to slip, throwing the whole thing out of time.
  • arnego2
Posted October 08, 2008 - 06:10 AM
Hallo Grayracer 513
How are those guys at EDCo? Costwise, timewise? I also found Millenium and Langcourt on the Net and wonder if anyone has some Info about them too?
regards
Arnego2
Posted October 08, 2008 - 07:41 AM
I have no direct experience with them, but EDCo has received good reviews on both their work and price from those here who have used them. Contact them yourself to ask about specifics.
  • tdamore
Posted October 08, 2008 - 09:27 AM
Yeah, I thought about that. I sent the whole head to Mike, cams included. I figured I'll just let him sort it out. This way I can be confident it's done right.
  • tdamore
Posted October 08, 2008 - 03:53 PM
I was reminded today of two very important things when working on engines:
1. Wear gloves.
2. Engine cases are sharp.
Unfortunately it took 9 stiches and an afternoon wasted at Urgent Care to remind me :lame:
I lanced the top off of the first knuckle on my middle finger while pulling the right side cover to get at the oil pump. I was sitting there looking at my knuckle bone thinking "Thats gonna leave a scar". Guess I'll be leaving things alone for a few days....
  • krzyaszwhiteboy
Posted October 09, 2008 - 07:20 AM
hahahahahaha sorry for laughing, but I have been there and done that, and was picturing myself sitting in my garage doing the exact same thing. Then I was picturing myself trying to talk my wife out of making me go to the ER
  • tdamore
Posted October 09, 2008 - 08:59 AM
LOL - I was actually considering just using crazy glue to close it up but my wife made me go to urgent care.
  • Hot  113 replies
  • 0 replies
