02' 426 bogging at 3/4 and up throttle
5 replies to this topic
  • thumpinyz
Posted October 01, 2008 - 03:13 AM
Heres my scenario,
I had not ridden for about 2-3mo
the gas had been drained
put fresh gas in
when I went to ride it started just fine and during my first session i just putt putted around with no problems seemed to be running good
during my second session i started to pick the pace up a little and the bike started to bog and sputter when i would get on it coming out of corners.
i changed the plug, it looked a little rich, but then it always has
during my third session I thought the problem was fixed but a couple of laps in it started to do the same thing.
It starts and runs fine, it just boggs when i hammer down on it, as i am writing this i begin to wonder if it happens when it gets warmed up or if I am just not getting on it soon enough to notice it in the beginning.
I am going to pull the carb and clean it up good especially the main and needle jet. I guess my real question is this, could it be the CDI or something electrical?
any ideas would be much appreciated
thanks
Lyn
Posted October 01, 2008 - 06:13 AM
It's almost certainly the carb. It could have something to do with a cold engine, but most likely, it's the main jet and/or needle jet partially blocked.
  • thumpinyz
Posted October 02, 2008 - 02:44 AM
thanks grayracer
there did appear to be quite a bit of build up in the main jet. I will re-install the carb tonight and run it. hopefully it will be fixed, if not I guess i will start trying to find the best price on the CDI box?
lyn
  • 99ncxj
Posted October 02, 2008 - 09:30 AM
seriously doubt its the cdi.
sounds like classic "trash in carb"
  • cowboyona426
Posted October 02, 2008 - 10:39 AM
I had that problem once... the plate in the home brew PowerNow I had on the bike had bent upward. I removed it and threw it out, it never did anything for the bike anyway. If your bike has something similar I'd at least check it out.
  • thumpinyz
Posted October 02, 2008 - 10:55 AM
99 -- I sure hope your right, we will see this afternoon
cowboy-- I dont have any of those powernow inserts just a boyseen quickshot.
I really think it is the main jet it was pretty clogged up.
thanks alot though for yalls inputs I appreciate it. I will update tomorrow after the test ride tonight.
I keep trying to talk myself into a new bike but I just cant get rid of this ol faithful thing, its probably going to take a catastrophic (sp?) failure before I can part with it I have become really attached to it.
lyn
  • 10 replies
  • Hot  38 replies
  • Hot  28 replies
