Oil question NOT just the normal what oil to use
6 replies to this topic
  • Kalar01
Posted September 29, 2008 - 08:02 PM
Once you use synthetic oil in your gearbox/clutch can you go back to using non-synthetic oil? (I have a 08 yz 450)
Thanks for your help
:lame:
  • Gerry B
Posted September 30, 2008 - 12:35 AM
yes you can
  • Wabbit16
Posted September 30, 2008 - 01:08 AM
I also wondered that once. I was young tho', and I had weird propabilities like 'the clutch plates could absorb the oil' or 'it would stuff up the bearings'. Ag but I was young and didn't know any better. I'm sure it'll be fine
  • reconranger
Posted September 30, 2008 - 05:00 AM
:lame:
Sure, but going back to dead dinosaur oil would be a downgrade from synthetic!!!
Posted September 30, 2008 - 07:11 AM
Of course you can, but why would you want to?
There are a very few oils that require flushing of one oil to change to another, including Castor based oils, and really unusual ones like the non-Newtonian 215.VM2.K5 fork oil from Smart Performance. These, however, are almost always labeled, "Do not mix with other lubricants".
  • Kasjok
Posted September 30, 2008 - 08:53 AM
What`s the difference between synthetic and full-synthetic oils? I am using this oil
http://www.statoillu...y_MC_10W-40.pdf
Seems to be quite decent, but I am not an expert by any means.
Posted September 30, 2008 - 10:33 AM
Speaking in general terms, synthetic is an oil with a manufactured base oil. "Full synthetic" is the same thing, stated that way to set it apart from oils that are blends of synthetic and refined petroleum base oils.
There has been a considerable bit of abuse of the term "synthetic", which by definition means "artificially made", or "manufactured", as opposed to "natural". In the late 1990's Castrol started marketing a very highly refined oil (a group III petroleum oil) as "SynTec Full Synthetic". Mobil sued, pointing out that it had no synthetic base oil in it at all. Castrol argued that the oil was so highly refined as to have been "remade", and some idiot in black robes agreed. After that, a great many oils were reformulated to use group III oils in place of true synthetic base oils. Less of that goes on today than it did then, but it still happens too often. Research the oil you use and see what it's really made of.
  • Hot  38 replies
  • Hot  50 replies
  • 0 replies
  • 5 replies
