What is a good Triple clamp for 2008 450F
4 replies to this topic
  • gtxkid
Posted September 29, 2008 - 05:16 PM
I have a 150.00 gift cupon for Pro taper or Arai or Answer or MSR.
I was looking to use it on the Pro Taper Triple clamp.
Do you guys know of a better one or is this a good one.
Also should i look at just the top or there whole setup.
Thanks Greg
  • MotoXT
Posted September 29, 2008 - 05:21 PM
I've got the Pro Taper and really like it. You can adjust it fore and aft to dial it in. I would just get the top. The bottom is nice but it's really just a bling factor, doubt you would notice any performance improvement. Just my 2 cents.
  • gtxkid
Posted September 29, 2008 - 05:54 PM
Can you adjust the bar height up or down at all
  • DPW
Posted September 30, 2008 - 02:40 AM
I use BRP and they have several options to meet your requirements...call or check out there site....
http://www.brpmoto.com/
http://www.brpmoto.c...clamp_info.html
  • Slinkyman16
Posted September 30, 2008 - 10:34 PM
are u looking to change the offset angle.. or just get some bling? if ur looking for some offset clamps.. depending on what exactly ur looking to get as far as handling.. applied 24mm, rg3 22mm and pc 22.5 mm offset.. are all good clamps.. i just got the pc 22.5mm offset clamps and they are awsome.. cnc machined and look trick.. as well as perfom..
