5 replies to this topic
  • blue_beast_wins
Posted January 05, 2003 - 05:08 PM
Gear box
Thought i may let you guys now for future reference that if third pinion gear has broken and takes out shift fork #2 you may have to fit a sleeve to your case or cases were the shift fork slides, the ID can be damaged so that shift fork #2 will tilt and fail to slide 3rd pinion gear eather way, you can't select 4th and 5th gears, i used a 12x10mm brass sleeve in the right hand half.
  • adamwagar
Posted January 05, 2003 - 05:39 PM
Thanks for the info. Hope I never need it. Hope you never need it again.
  • blue_beast_wins
Posted January 05, 2003 - 06:01 PM
So do i :)
  • YZ_Abuser
Posted January 06, 2003 - 02:12 PM
And how did you figure that out?
  • blue_beast_wins
Posted January 06, 2003 - 03:10 PM
Took a couple of hours and several Wild Tukeys after i'd bolted the cases together, striped it, bolted it, striped it, measure this measure that, enjoy the benifits :)
  • dirtdynamics
Posted January 06, 2003 - 09:45 PM
