2 stroke mix in a 450?
14 replies to this topic
  • ivesy
Posted September 25, 2008 - 12:08 PM
Does anyone know of any issues (plug fowling/power loss etc) from running a 40:1 two stroke mix in their 4 stroke? I always have too much going to waste after using the 125 so it would be sweet if I could use it up in the 450.
Cheers
  • KJ790
Posted September 25, 2008 - 12:12 PM
Don't do it, it won't run well. You are better off putting it in a car with a full tank of gas. 1 gallon of premix on top of 15 gallons of straight gas in a car won't affect it.
  • Wiz636
Posted September 25, 2008 - 12:16 PM
I accidentally dumped about a gallon of 32:1 for my son's YZ250 into my 450. Once I realized it I stopped and topped off with regular gas. This was in my IMS 3.2 gal tank so the resutling mix was roughly 96:1. Never noticed any difference except that the exhaust smelled good.
Typically when I have premix (from the YZ250, chainsaw, weed eater, etc.) that is getting old I just dump it in the creek. Lol...just kidding. I dump it into my kid's cars. A gallon or two of premix mixed in with the amount of fuel a car hold is no problem.
  • Thrasherg
Posted September 25, 2008 - 12:28 PM
As mentioned, if you don't thrash the bike, it's unlikely to do any harm, but you would be much better off putting in a full car tank of gas.. Because of the oil mixed with the gas, your engine will run leaner with this fuel and the oil will cause deposits (soot) which whilst unlikely to damage anything aren't meant to be in your engine. The same is true on a car engine, but your car engine is tuned to a much lower level than your motorbike, so the engine suffers far less from the oil mixture, and the car gas tank has far more gas in it, so the oil mixture gets diluted to the point that it's almost like pure gas..
  • pbviking
Posted September 25, 2008 - 12:46 PM
IMO
If you notice the mistake why not just drain the gas tank? Its really not hard.
Loosen the clamp, pull the hose, and drain the gas.
To each its own I guess
Posted September 25, 2008 - 01:14 PM
There was no mistake. Read the first post.
  • ivesy
Posted September 25, 2008 - 11:42 PM
Thanks for the great advise guys, I'll just use it to kill some weeds round the house then :excuseme:
  • Ga450owner
Posted September 26, 2008 - 07:44 AM
Thanks for the great advise guys, I'll just use it to kill some weeds round the house then :lame:
RoundUp is much more enviromentally friendly for weed killing...........give it 2 a 2stroker who is low on premix oil:thumbsup:
Posted September 26, 2008 - 08:06 AM
The three correct ways of using it up would be (all already suggested):
> Two stroke lawn implements
> Dilute with straight gas at least 1:1 and use in a car
> Dilute with straight gas at least 1:1 and run in your thumper
  • aggiemoto99
Posted September 26, 2008 - 01:52 PM
If you jetted for it....it would run fine. I don't even think build ups or gunk would be an issue at all if it were a decent premix.
But as a side note, I run it in my z50 when I don't have any other gas and that is often (big bore 88 high compression etc...) and it runs fine.....that bike runs on almost anything though...
  • detonator01
Posted October 11, 2008 - 05:31 PM
Cheers
I ran 40:1 in my 04 it ran fine.
  • USED YZ426F
Posted October 11, 2008 - 06:37 PM
I've run 32:1 (left over from my 490) in my '00 426 when I was out of straight gas. I really didn't notice any difference in power or performance. The bike smoked very slightly, but it was hard to notice.
I never really thought about potential jetting problems, as I usually run at sea level to about 2K feet.
Posted October 11, 2008 - 07:37 PM
One thing that should probably be mentioned here is that oil in the gas reduces the anti-knock index (the effective octane number) of the fuel. and is one of the reasons two strokes often need higher octane fuels than modern Thumpers.
  • aggiemoto99
Posted October 12, 2008 - 03:49 PM
32:1 is what, 3% oil? I don't think it lowers it enough to worry about, but good point.
It would lean your jetting out some, but not a heck of a lot.
  • YamaLink
Posted October 13, 2008 - 07:22 AM
A group of us had a ride that went longer than expected (read: we were lost) a few weeks ago, and two YZ450 riders dumped 32:1. About half a gallon each! Yikes.
Bikes ran fine, smelled good, and have had no ill effects since.
