What does JD Blue .......refer to, WR450 Jetting question
9 replies to this topic
  • JKoz
Posted September 25, 2008 - 09:59 AM
I recently picked up a new 06 WR450 and have been doing tons of research and have a lot of the "free" mods already done. This weekend I'm re jetting and AIS kit install...... what my question is.
What does the below JD Blue #5 refer to?
I order main jets, pilot jets, and a few leak jets but what is the JD-----?
Thanks in advance and this forum has a lot of good information.
FYI- pipe mod, grey wire, air box mods are already done and have made some inprovement. Looking forward to jetting and throttle stop removal. I hope this wakens this thing up a lot :excuseme: because I have a 4 day weekend to ride.
http://shop.thumpert...talk_aissrk.htm
re-jet the bike using INDY450's jetting chart:
Elevation 0 to 4,000. feet
30 to 45 degrees: 172 main, JD Blue #5, 48 Pilot, 2.0 turns, 75 starter jet, #0 leak jet
and refer to my tutorial when jetting:
http://www.thumperta...ad.php?t=309069
  • squid
Posted September 26, 2008 - 11:37 PM
number 5 is the position you put the needle clip in.
  • jandmsuburban7
Posted September 26, 2008 - 11:47 PM
Hi, the JD jet kit has two needles in it. Both have a different taper for that in short may be explained one for winter and one for summer and one for low altitude vs. high altitude. Cant remember which goes to which though. They are definately different though as having tried them both. Have fun and stay safe. Jason
  • William1
Posted September 27, 2008 - 03:25 AM
James Dean jet kits come with two needles. The color of the needle is painted in the top/flat of the needle. The blue is a cold weather, low altitude choice, the red is a warm weather, high altitude choice.
  • KennyMc
Posted September 27, 2008 - 07:07 AM
FYI- pipe mod, grey wire, air box mods are already done and have made some inprovement. Looking forward to jetting and throttle stop removal. I hope this wakens this thing up a lot :lame: because I have a 4 day weekend to ride.
I refers to the clip position when counting from the top.
  • JKoz
Posted September 28, 2008 - 05:40 AM
THANKS for the info. The GYTR AIS kit came with an adjustable needle in it and I ended up guessing at where I should put it in realationship to the stock non adjustable.......... I think I was wrong.
This is the problem now---- when i grab a handful of fun on the throttle, there is no fun and it just dies. Falls flat on its face and if I hold the throttle at all it will stall.
Factory // // What I did
45 // Pilot // 48
165 // Main // 168
50 // Leak Jet // 40
65 // Starter // 72
Adjustable fuel screw is 2 turns out
Adjustable needle is set so it is one knotch lower in the carb-- I think this is wrong and will be changing it today.
Grey wire snipped
Exhaust modded
Air box modded
Ais Removed
Any ideas other than I screwed up somewhere?
  • Fullbore4
Posted September 28, 2008 - 06:33 AM
AIS needle is probably bent and jetting is rich. Put stock jets and needle back in. They will also be rich unless you get a pipe.
  • JKoz
Posted September 28, 2008 - 06:44 AM
Every thing I've read from a lot of folks on here have done these mods with sucess with out having the need for a full pipe replacement. I did remove the stock silencer tip that restricts it down a ridiculas amount.
As for the Jets I know for a fact it was already running lean before opening up the intake / exhaust so by doing those it would make it even leaner.
Your correct--it wouldn't need much of a tweak for the needle to be bent and considering the (no packaging) that might be it.
I'll be pulling the AIS needle out in just a few.....was going to change the depth but I may just put the stock one in it to see what happens.
  • suzukipoo
Posted November 04, 2008 - 01:41 AM
I just installed new jets last night and did the o-ring mod!
2007 WR450. 4000-6000f, 75-95 Ferenheid
Main jet 165
Pilot jet 45
Leak jet 40
Fuel screw 1.5
Just make sure that the AP screw is set at what the manuel (2007) shows mine is on page 4-19!
  • Charles De Mar
Posted November 04, 2008 - 09:18 AM
You can get a 05 yz450 stock needle. then use the yz450 jetting section of the 05yz450 manual for a starting point.(manuals are available online) I no longer use the JD needles and the YZ needle is much cheaper. that worked the best for me on my '06.
