Broke my E-Series
2 replies to this topic
  • JT1
Posted June 17, 2002 - 07:12 PM
I'm not exactly sure how it happened but I think it was from casing a double. The 2" pipe that is welded to the larger 5" canister broke in a complete circle. The clamp that is towards the engine may have vibrated loose making the bolt a pivot area and the impact of the jump may have caused stress on the pipe.......at least that is what i'm telling myself .
anyone experience anything like this?
Has anyone put a spark arrester on their stock pipe (promoto billit)? was it easy to do?
  • JaZ
Posted June 17, 2002 - 11:33 PM
I had the same problem but had about 15mm left on when I noticed it.
Just took muffler to a aluminium welder and he not only fixed it but beefed it up as well, as this is a weak point, cost me $25 AUS
Also had a problem with the internal scread seperating from the flange as they are only tacked on, might pay to check them.
Good Luck
  • JT1
Posted June 18, 2002 - 04:23 AM
Jaz, what's a scread? thx, i'll call some local welders and see if they can fix it.
