426 overheating Badly
2 replies to this topic
  • racerx573
Posted September 24, 2008 - 01:37 PM
Here's my scenario, I have the engine in a quad frame for MX.
I have a 42 pilot
172 Main
Needle is on the 3rd clip (stock needle)
It's ported, K&N filter, 13:1 piston, 450 cam mod.
Wet sump kit
It has no response off the bottom end, but screams once it is wound it, but takes a while to get there. I just checked out all the jetting guides and printed them out to try some different combos.
My plug is burning kind of a grayish brown, and my exhaust tip is a little white, so she was running lean.
When I come off the track the coolant is down to the fins in the top of the rad, and she is blowing steam furiously.
I installed a catch bottle, and a high pressure radiator cap.
I figured since it was running like that I may have a leaky head gasket, so a new one is on the way, and there was a minute amount of drip from my weep hole, so I ordered a new mechanical seal.
I am going to try all of this, and run the jetting I was running before.
But if anyone else has any insight, I would greatly appreciate it.
Posted September 24, 2008 - 02:06 PM
First, confirm that the flywheel key is intact by checking actual TDC through the spark plug hole against the timing marks. Then check the cam timing.
  • racerx573
Posted September 24, 2008 - 02:26 PM
I've got the whole head off right now still, I am gonna check all the timing and whatnot in reference to the YZ450 cam mod thread. I bought the engine used, so something could be out of line. What should I check for when checking the flywheel? Thanks for the info.
  • 10 replies
  • Hot  50 replies
  • Hot  30 replies
