2008-09 YZ450F User Jetting Database
24 replies to this topic
  • todds924
Posted October 09, 2007 - 06:29 PM
Finally got my 08 dialed in for the Pro Circuit Ti-4 pipe. All the jets were changed from stock settings. Here is what i ended up with and the bike runs perfect for Sea level/So.Cal tracks. 165 main/from160------43 pilot/from45----------NFPP needle/from stock--------50 leak jet/from 55----2 turns on the mixture screw.:confused:
  • RJB
Posted April 28, 2008 - 02:02 AM
I need to same info, anyone have the #'s out there for us stock people? I'm at sea level also. My Wife bought me an 08 for Christmas and it doesn't like to start very easy.:eek:
In the Australian Dirt Bike mag shootout, they used the following
Bike: 08 YZ450
Main Jet: 158
Pilot Jet: 45 (stock)
Starter Jet: stock
Needle: NFPR (stock)
Clip: 4th
Leak: stock
Fuel screw: 2.5 (stock)
March 08 Motocross Action Mag
Bike: 08 YZ450
Main Jet: 160
Starter Jet: stock
Needle: NFLR (stock)
Clip: 3rd
Leak: 55
Fuel screw: 2-3/8
Comment "Apart from fuel screw adjustments, the YZ450F ran like a top."
My settings (sea level, hot, high humidity)
All stock - starts & runs okay (usual bog off idle and slight popping on throttle chop). It only has 3 hours, so will fine tune with a couple more hours
  • Windseeker
Posted June 03, 2008 - 09:16 PM
Bike: 08 YZ450
pipe - Yoshimura RS
sea level, temp 10-15 degrees C
Main Jet: 165 (tried with 160 and 170 - no difference felt)
Pilot Jet: 48
Starter Jet: stock
Needle: NFLR stock
Clip: 3rd
Leak: 50
Fuel screw: 0
Ok - after the pipe came in the decel pop was heavy and annoying. Advice that I got here was 48 pilot, 50 leak and needle up one groove. Got the jets yesterday...
the swap from all stock carb DONE yeasterday. Oh, and I have Ride Eng fuel mixture screw. But it works funny.
Now I have anoying bog (to the extent engine dies at sharp throttle opening) , same (if slightly less) decel pop...
and the funny thing is the engine works with th fuel screw fully in! it continues to work with no audible difference till 2,5 turns, then rpm falls...
on stock carb the same screw worked on 2,5 turns, and rpm started to fall at about 0,5 turns....
:thumbsup:
  • motoman063
Posted June 04, 2008 - 07:18 AM
I have spent alot of time on jetting this bike, with these specs the bike is crisp off the bottom and very strong in the midrange and no popping at all!
42 pilot
165 main
nfpp needle 4th position
55 leak jet
1/-1/2 fuel screw
  • YamahaDude450F
Posted June 27, 2008 - 07:46 AM
Model: 2008 yz450f
Main Jet: 160
Pilot Jet: 48
Starter Jet: Stock
Leak Jet : 55
Fuel screw/Setting: 1 3/4
Needle/Position: Stock
Air box/Filter: Twin Air
Pipe/muffler: Stock
Altitude: 600-1600
Temp: 75-90 degrees
Humidity: varies
This jetting works awesome for me i have great power everywhere with NO bog or hesitation. I also have done the O-ring mod with a 1/8 thickness o-ring, installed a boysen quickshot accelerator pump cover, put in a boysen powerblade on the air boot, and cut out the screen on the air filter cage. Bike RIPS now!
Posted September 22, 2008 - 08:07 PM
READ BEFORE POSTING!: This thread is intended to be used as a reference collection of jetting used by members ONLY. Please use the provided template below, and post only the jetting you currently use, along with any pertinent comments. Post only in the correct thread for your model bike.
DO NOT ask questions or discuss the information posted here in this forum. If you want to talk about anything here, please do so in a new or current thread on the topic and use a link to the particular post you wish to discuss. Posts not complying with this format will be removed without comment.
NOTICE:The people who post here are of all skill levels. This information is only intended to let you see what others are using, and cannot be taken to mean that the information is accurate, will apply to your use correctly, or even that the poster's bike runs right with the posted setup. Use it as a guide/starting point only, and look at as many relevant postings as you can before proceeding.
POST ONLY INFORMATION APPLICABLE TO 2008-09 YZ450F MODELS IN THIS THREAD.
Post your jetting using the template below (copy and paste to your post) and please be as complete as you can. In the Comments section please include any modifications you feel will have a bearing on the jetting, such as cams, accelerator pump mods, bored carbs, etc.
Model:
Edit Revision Date:
Main Jet:
Pilot Jet:
Starter Jet:
Leak Jet:
Fuel screw/Setting:
Needle/Position:
Filter:
Pipe/muffler:
Altitude Range:
Temp Range:
Humidity Range:
Comments:
OEM 2008 YZ450F(X)
Main Jet: 160
Pilot Jet: 45
Starter Jet: 72
Leak Jet: 55
Fuel screw/Setting: 1.5-2.0 turns out
Needle/Position: NFLR-3
  • Scooter426
Posted October 05, 2008 - 12:03 PM
2008 YZ450F
Main Jet: 165
Pilot Jet: 45
Starter Jet: 72
Leak Jet (if any): 55
Alt: Sea level - 500 ft (Seattle, WA)
Pipe: Dr D full system, stainless.
Air filter: Stock
Comments: Still pops on decel, may try raising the needle 1 clip, and one size bigger pilot jet. This bike is VERY fast up top. I mean VERY fast. I thought my 04 was fast, but this bike with a DR D pipe blows the 04 away. It feels like I could put 1-2 less teeth on the rear and it will pull it easily.
  • MX926
Posted October 12, 2008 - 08:34 AM
2008 YZ450F Minnesota
170 main jet
45 pilot
55 leak jet
stock needle
Fuel Screw 1.5-2
It seems to run great above 60 degrees, pops in cooler conditions needs more fuel in the middle.
  • gerbrony450
Posted November 10, 2008 - 11:41 AM
Bike: 2008 YZ450
Main Jet: 160
Starter Jet: stock
Clip: 3rd
Leak: 55
Fuel Mix: 2 turns out
Stock 08 Pipe with PMB. No popping on decel fires on first kick when hot.
Riding in California sea level - 1500ft 60-80 degrees
  • jonova
Posted January 12, 2009 - 07:31 PM
Model: 2008 YZ450
Edit Revision Date: 1/12/08
Main Jet: 168
Pilot Jet: 48
Starter Jet: STK
Leak Jet (if any): STK
Fuel screw/Setting: 1.25
Needle/Position: NFLR - 3rd clip (STK)
Filter: Stock
Pipe/muffler: Pro Circuit T4 Slip on
Altitude Range: 0-1000'
Temp Range: 65-90F
Humidity Range: ?? Dry Desert
Comments: I tried 165 main 4th clip and 45 pilot but it was a bit lean. With the above setup the bike starts easier and runs better. Although, typical off idle bog if you slam it open, I plan to play with the AP spring and leak jet.
  • 00LS1SS
Posted February 06, 2009 - 11:14 AM
Model: 2008 YZ450 stock pipe
Edit Revision Date: Feb 09
Main Jet:160 cold/155 warm
Pilot Jet: 42
Starter Jet: STK
Fuel screw/Setting: 2 1/4 cold or 2 out warm
Needle/Position: NFLR - 2nd from top(STK)
Filter: Stock
Pipe/muffler: stock w/quickshot Altitude Range: 2370-2500ft
Temp Range: 30 up to 90F
Humidity Range: ??
Bike starts better than ever before.Quicker response then ever. Will have update as soon as new tires and clutch installed asap and a real ride is taken at about 30-40F.May put needle back to stock 3rd position.
  • davcon
Posted April 15, 2009 - 06:24 AM
Main Jet 160
Pilot Jet 45
Leak Jet 55
Stock Needle Position 3
Fuel Screw Turns 1-1/2
Altitude 5-7k
Temperature F 50
Plug Condition white
Result No Complaints
Stock 2008 YZ450 w/ PMB Spark Arrestor
Its running a bit lean but when I change the clip to 4 it "lopes" at low throttle. Just bought the bike new Nov 08 so havent had a chance to experience warm weather jetting yet. I suspect it will be pretty close.
  • Lankyrider
Posted August 30, 2009 - 11:05 PM
Bike - YZ450f 2008
Main Jet - 170
Pilot Jet - Stock
Leak Jet - Stock
Needle - JD Blue Neede Position 3
Fuel Screw - Merge racing Turns 1-1/2
Altitude - 0 - 3000f
Temperature - 27-36C'
The bike has more power and speed than ever and no popping at all.:ride:
  • Steel Panther
Posted June 21, 2010 - 03:49 PM
Model: 2009 yz450f
Edit Revision Date: 6/21/10
Main Jet: 165
Pilot Jet:stock
Starter Jet: stock
Leak Jet:stock
Fuel screw/Setting: 2 1/4 out
Needle/Position: stock nedle 4th position
Filter: twin air
Pipe/muffler: fmf 4.1 with megabomb
Altitude Range: 700ft
Temp Range: 80-90°F
Humidity Range: uhhhh sunny southern CA
Bike starts second kick cold, first kick hot. After I put on the pipe the bike felt like it ran strong just had a lot of decel pop. Turned to fuel screw to 2 1/4 out from 1 1/2 stock and raised the clip and popping/backfireing is all gone once the bike warms up and it has good throttle response.
  • SAthump
Posted November 05, 2010 - 10:06 AM
[COLOR="Blue"]Model: 2009 YZ450f
Edit Revision Date:
Main Jet: 160 stock
Pilot Jet: 45 stock
Starter Jet: stock
Leak Jet: R&D powerbowl / AP / stiffer spring
Fuel screw/Setting: Zip Ty screw / 2 out
Needle/Position: NFLR 3rd stock
Filter: UNI
Pipe/muffler: Megabomb / 08' stock can w second baffle removed / PMB
Altitude Range: 700'
Temp Range: 70*
Humidity Range: 60%
With my wideband idle is 14.2-13.8 progresses smoothly down to 11.5 throghout the throttle range. The stock jetting is wonderful on this bike. Starts on first kick warm and cold; I love this bike.[/COLOR]
  • curtis515s
Posted November 22, 2010 - 10:07 PM
Model: 2008 YZ450F
Edit Revision Date:
Main Jet: 160 (Stock) Going to try a 165 if it stays under 60 deg. this weekend
Pilot Jet: 48
Starter Jet: Stock
Leak Jet (if any): Stock
Fuel screw/Setting: Works Connection Screw 1 1/2 out
Filter: No Toil
Pipe/muffler: Stock Header, FMF Powercore 4
Altitude Range: 0-2500
Temp Range:55-80
Humidity Range: Very little/ Northern CA
The 48 pilot made a huge difference in throttle response and very little popping on decel now.
  • FZ1426
Posted January 06, 2011 - 08:51 PM
Model: '09 YZ450
Edit Revision Date: 1-5-11
Main Jet: 165
Pilot Jet: Stock
Starter Jet: Stock
Leak Jet (if any):
Fuel screw/Setting: 2 1/4 turns out
Needle/Position: NFLQ-4th from top
Filter: Stock Filter/YZ250 filter cage
Pipe/muffler: MRD Full System
Altitude Range: 500-3000 ft.
Temp Range: 50-90 degrees
Humidity Range:
Comments:
Edited by FZ1426, January 14, 2011 - 07:28 PM.
  • flac5364
Posted May 12, 2011 - 12:57 PM
Model: 2009 YZ450FY
Edit Revision Date: 05/12/11
Pilot Jet: 45 (Stock)
Starter Jet: n/a
Leak Jet (if any): 55 (Stock)
Fuel screw/Setting: 2 1/2
Needle/Position: NFLR-3 (Stock)
Filter: Twin Air
Pipe/muffler: FMF Q4
Altitude Range: 2500
Temp Range: 70 Degrees
Humidity Range: Low/Dry
Comments: Bought the bike second hand and trying to get a "Stumble" or rough mid-range cleared up. I have dropped the clip position to both the 4th and 5th position and have NOT cleared it up. Gonna try to raise it to the 2nd this weekend.
Edited by flac5364, May 13, 2011 - 02:32 PM.
  • NewMexican
Posted July 14, 2011 - 05:05 PM
Model: 2008 YZ450F
Edit Revision Date: 07/14/11
Main Jet: 162
Needle/Position: NFPP-3
Filter: No-Toil
Pipe/muffler: FMF PowerCore
Altitude Range: 5500
Temp Range: 80 Degrees
Runs great, had stock 160 main on other bike (have two of the same model), major decel pop and raced at El Centro sea-level but it burned up crank (too lean). Rebuilt with big-bore and plan to run 165 main in it in the future, maybe go to JD red needle on it, but JD seemed too rich with stock cylinder.
Edited by NewMexican, July 14, 2011 - 05:07 PM.
Update 1/2 step richer Needle P/N info
  • ttr250dude
Posted July 14, 2011 - 11:07 PM
Model: 2008 YZ450f
Main Jet: 165-168
Pilot Jet: 48
Starter Jet: Stock
Leak Jet: Stock
Fuel screw: 1 1/2 - 1 7/8
Needle/Position: Stock, Stock
Filter: Twin Air
Pipe/muffler: Stock with Lexx endcap
Altitude Range: 800'-1,000'
Temp Range: 70-95 F
Humidity Range: 95%-100% Freaking humid (Wisconsin)
Comments: My bike runs crisp with this jetting and starts 2-3 kicks cold with choke and 1-2 kicks hot with hot start. Very slight pop on decel.
Edited by ttr250dude, July 14, 2011 - 11:34 PM.
  • Hot  33 replies
  • 5 replies
  • Hot  79 replies
