05 YZ 250. (clutch)
19 replies to this topic
  • zared
Posted 21 September 2008 - 01:08 PM
Ok, so i put it in gear with the clutch in and try to roll it, HA...acts like the clutch is engaged, adjusted clutch @ lever, still nothing. i need manual for the bike does anybody have?
  • zared
Posted 21 September 2008 - 01:24 PM
help:confused:
  • RTSinDallas
Posted 21 September 2008 - 01:43 PM
What did you need to know?
  • zared
Posted 21 September 2008 - 01:54 PM
why when I roll it with the clutch pulled in with the bike in gear act like the clutch isnt pulled in, for example when i push it, say's in first gear and i have the clutch pulled in, the bike doesnt wanna roll smoothly
  • zared
Posted 21 September 2008 - 03:13 PM
:excuseme: :lol: :excuseme: :banana:
  • MJP68
Posted 21 September 2008 - 03:36 PM
the clutch is dragging. make sure your freeplay is adjusted properly at the lever and the clutch and engine are warmed up.  If there is still some drag you need to inspect the clutch.
if you are using a heavy weight fluid the clutch will drag when cold.
  • zared
Posted 21 September 2008 - 03:45 PM
well i need the service manual know where i can get one
  • zared
Posted 21 September 2008 - 03:56 PM
*Note, I adjusted Clutch Freeplay to specs, and still does it BAD...iunno man, shit.
  • RTSinDallas
Posted 21 September 2008 - 04:16 PM
It should be the same as your 98. Might be warped plates or a groved basket. I would drain the oil and pull the the clutch cover and check things out. For the manual you can check at the dealership or online. Also, you may check out cyclepedia.com, they do online manuals. I used them for my KDX200, it was fine for my needs.
  • zared
Posted 21 September 2008 - 04:24 PM
i wanna pull it off, but dont wanna replace the gaskest lol im so broke..
  • RTSinDallas
Posted 21 September 2008 - 04:34 PM
It has an o-ring.
  • zared
Posted 21 September 2008 - 05:05 PM
oh forreal the clutch cover does?
  • ThumperKid250F
Posted 21 September 2008 - 05:24 PM
yes it has a O ring for the clutch cover
  • zared
Posted 21 September 2008 - 05:33 PM
badass
  • shrubitup
Posted 21 September 2008 - 08:40 PM
zared said:
badass
fo sho
  • hallsy
Posted 22 September 2008 - 05:58 PM
See MJP68's post, cold clutch? If so, no roll in gear = normal.
  • zared
Posted 22 September 2008 - 06:14 PM
thanks
  • Matt_W
Posted 22 September 2008 - 06:21 PM
Even on a properly adjusted clutch with new components, there is still a bit of drag when you try to push the bike in gear with the clutch lever pulled in.  My two smoker does it, and my brand new 08 YZ450F does it and I've only ridden it up the street and back so far.  Unless it's a problem while the bike is being ridden (i.e. shifting or stalling), I wouldn't worry about it.
  • mxjosh
Posted 22 September 2008 - 08:43 PM
PM me your email address for an 06 manual...everything but the front forks should be applicable to 05.
  • MJP68
Posted 22 September 2008 - 09:41 PM
copy and paste.
this site has most 00-07 yamaha manuals for free download (pdf format)
download and save, print the pages you need or print the whole thing!!
http://www.yamaha-mo...ice/manuals.jsp
