Which YZ Needle?
22 replies to this topic
  • 123BigcoopDawg576
Posted September 15, 2008 - 05:41 PM
Well its time to buy some jets and i think im going to try the yz needle before i do the JD jetting kit. but the question becomes which needle are you guys using or recommend?
13 SKU: 5TA-14916-LR-00
NEEDLE (#NFLR) STD STD 1 $9.76 Add to Cart
13 SKU: 5TA-14916-LN-00
NEEDLE (#NFLN) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-LP-00
NEEDLE (#NFLP) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-L1-00
NEEDLE (#NFLQ) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-LS-00
NEEDLE (#NFLS) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-LT-00
NEEDLE (#NFLT) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-LU-00
NEEDLE (#NFLU) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-PN-00
NEEDLE (#NFPN) AP AP 1 $10.38 Add to Cart
13 SKU: 5TA-14916-PP-00
NEEDLE (#NFPP) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-P1-00
NEEDLE (#NFPQ) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-PR-00
NEEDLE (#NFPR) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-PS-00
NEEDLE (#NFPS) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-PT-00
NEEDLE (#NFPT) AP AP 1 $9.76 Add to Cart
13 SKU: 5TA-14916-PU-00
NEEDLE (#NFPU) AP AP
  • SXP
Posted September 16, 2008 - 05:58 AM
Check this thread out. The consensus seems to be between the 05 YZ (N???)stock needle (per the original poster), and the 08 YZ (NFLR) stock needle.
http://www.thumperta...ad.php?t=683783
BTW, congrats on the 08. You going to plate it?
  • 123BigcoopDawg576
Posted September 16, 2008 - 05:59 AM
It is no longer possible to plate a bike in Cali!
  • beezer
Posted September 16, 2008 - 06:45 AM
I'm using the NFLR in my 08 and it's the most bestest running WR450 in the hole wide world.
  • Charles De Mar
Posted September 16, 2008 - 07:49 AM
Really? What needle do you have in your Quad?
  • erickdj
Posted September 16, 2008 - 08:10 AM
My WR has an NFPP needle, works perfect. I use the WR anywhere from 500ft to 5k ft elevations, 40 to 105 degree weather and it never misses a beat, great response all around. I also have a 40 leak jet, o-rings on the AP arm, and a full yz exhaust. It's an 07 WR, by the way.
  • Charles De Mar
Posted September 16, 2008 - 08:16 AM
I have the NFLR that I have good results with. 'o6 wr450
  • beezer
Posted September 16, 2008 - 08:21 AM
[QUOTEReally? What needle do you have in your Quad?][/QUOTE]
My quad is fuel injerkted.
  • 123BigcoopDawg576
Posted September 16, 2008 - 08:31 AM
Do you have a part number for the NFPP?
And why that one over the others?
PS i ride the same locations as you...baja and so cal d38
  • Charles De Mar
Posted September 16, 2008 - 08:44 AM
Sounds messy!
  • beezer
Posted September 16, 2008 - 08:54 AM
It can be messy if you're riding with a full beer but otherwise it's okay.
  • 123BigcoopDawg576
Posted September 16, 2008 - 09:15 AM
Jets Order!
Went with the NFPP Needle
48 pilot
168 main
40 leak
besides the needle this is what my 06 had in it and it ran great so if i dont like the mid range...ill order the jd jetting kit
  • JSanfilippo
Posted September 16, 2008 - 11:08 AM
My WR has an NFPP needle, works perfect. I use the WR anywhere from 500ft to 5k ft elevations.
Oh you've had it higher than that.
These bikes are not a sensitive to jetting as I originally thought
  • JSanfilippo
Posted September 16, 2008 - 11:09 AM
Jets Order!
48 pilot
168 main
40 leak
What did you decide pipe wise?
  • erickdj
Posted September 16, 2008 - 12:42 PM
Jets Order!
48 pilot
168 main
40 leak
Looks like you already got the part number for the NFPP (SKU:5TA-14916-P1-00) I got that needle after I had to wait 2 months for an AIS kit that never arrived. So I decided to get a needle and some jets to form my own "kit". The parts counter guy asked one of their service techs who happens to own a small dyno testing shop, he said that given the location of my riding that was the needle he would have used. I was skeptical at first, but it has worked wonderfully for me. When I bought my 08 yz450 I also replaced the stock needle with an NFPP, got good results with that as well. I'm pretty sure those jet sizes you ordered are the same ones I'm running. That bike is going to scream!!! :lol: :excuseme: Hold on tight Aaron!:excuseme:
  • erickdj
Posted September 16, 2008 - 12:55 PM
You're probably right, now that I think about it, I might have had it a little past 6k ft. I like the fact that I don't need to re-jet it regularly like a 2-stroke.
Speaking of 2-strokes, that KX250 is my next project to re-jet. I'll have to figure out a good baseline for this area and temperature, then I can adjust accordingly at other locations/temperatures. I'm not liking the spooge running down the muffler and the oil spray on my jersey. :excuseme: :lol:
  • 123BigcoopDawg576
Posted September 16, 2008 - 01:42 PM
im really sold on the yz header since thats what my 06 had and i liked the way the dr d worked with it. as for the muffler i will probably go with an fmf pipe. when you call i can explain why.
however like i have said before i really want an aluminum muffler like the dr.d but i like how short and hidden the fmf is but all the high flow pipes are titanium which scares me...
  • beezer
Posted September 16, 2008 - 01:59 PM
You need the bigger YZ header to make it run right I think.
I have the Dr. D pipe and it runs great but it's a bit loud.
Dr. D reccomends a 162 main jet so that's what I'm running at sea level.
According to my S.O.T.P. dyno is spot on.
  • JSanfilippo
Posted September 16, 2008 - 03:43 PM
The powercore 4 is aluminum. Its the same "factory foward" design as the factory 4.1 ©, TI powercore, Q4, etc.
I think retail is like $289. I see them on e-bay in the low $200 range all the time.
  • JSanfilippo
Posted September 16, 2008 - 03:48 PM
:excuseme: Erick has premix bukkake :banana:
Wierd. Mine wouldn't run right even even with the 165. The 168 is spot on. I wonder if I could get more pull with a 170...not that I need it or anything.
Alot of company will not recomend non stock jets on EPA regulated motorcycles for fear of fine-age. Either from the feds or those bush humping fags at CARB
