chain lube???
7 replies to this topic
  • zaxcar1
Posted September 15, 2008 - 06:09 AM
i have a none o-ring chain and i have been using tri-flow and it dosent seem to hold up for trail rides. i tried some bellray stuff, thats i found out was more for road bikes. so whats good to use?
  • clutchless
Posted September 15, 2008 - 10:32 AM
i use maxima crystal clear chain lube.
it works well for me.
  • BASSic
Posted September 15, 2008 - 12:48 PM
I use Bel-Ray Super Clean chain lube, and it works well. It's not messy and doesn't attract grit or grime. I sprayed some on prior to a ride in some muddy slop. When I cleaned the bike off that night, the dirt rinsed off and the chain was still coated with the lube.
The trick with this stuff is to follow the instructions and let it set for 15 minutes before you ride. I've ridden immediately after spraying it, and had it fling off because the solvent didn't have time to evaporate.
Posted September 15, 2008 - 01:36 PM
Too many people overlook this simple fact, and then they complain about the lube flying off. Think ahead. Lube your chain AT LEAST an hour before you ride. I lube mine the night before.
:lol: :excuseme:
  • zaxcar1
Posted September 15, 2008 - 06:26 PM
my bell ray is the bell ray chain lube with exclusive molyphos additve for o ring and competition chains. when i used it it was on for over a hour and when i rode the trails it wore off after half the ride. when i went to the web sight it said for more road bike. with o ring chains.
  • Slinkyman16
Posted September 15, 2008 - 07:24 PM
maxima crystal clear.. syn version.. works prett good.. dosnt evap as well as i like but does clean up well and is great to use.
  • Justin89
Posted September 15, 2008 - 08:28 PM
I use the Honda chain lube...now it's called "Original" chain lube...it comes out clear and dosen't leave any grime behind.:excuseme:
  • AZ Thumpdaddy
Posted September 16, 2008 - 03:05 AM
I also use the Honda HP chain lube with Moly in the black can (used to be red) for both o-ring and non o-ring chains. Dirt does not stick to it and it does not fling off once dry. I usually apply the night before a ride.
  • Hot  33 replies
