To Rebuild or not to Rebuild?
13 replies to this topic
  • MountainMax
Posted September 15, 2008 - 02:27 AM
My 06 WR has over 6000km on her now, and that is not highway miles, it's mostly normal to hard off road driving with a little on road. I have no loss of power, noise or any other complaints, but I was wondering about re-ringing her or not over the upcoming winter (only 5 degrees c here now)
  • kskyles
Posted September 15, 2008 - 08:29 AM
Hey MountainMax-
My '05 is getting the top rebuilt right now. New piston, rings, valves, honing, etc...
I let it go too long. I did regular valve checks and was routine on my maintenance.
When they did the compression test, it was only holding about 35% of what it should.
If anything, I would get a compression test done to see how well the bike is doing. I don't think it would hurt anything.
I should have done that last year.
  • MountainMax
Posted September 15, 2008 - 01:12 PM
it's hard to do a compression test on these because of the auto decompression pin on them, they will never read as high as they should......
  • coloradobrad
Hey MountainMax-
+1, do a compression/leak-down test and then decide. You could opt for a high comp piston if you rebuild. Port/polish the head, bigger valves too :excuseme: With it being 5C outside now is the time...
  • JSanfilippo
Posted September 15, 2008 - 06:21 PM
Like mountain max said, its practically impossible to get an accurate reading with a compression tester. +3 on the leak down test. The dealer is likely taking you for a ride.
Mountain max, 6000 KM is roughly 3,728 miles. Thats really not a significant amount of time for these engines. Have the valves ever needed adjustment?
A piston, rings, and timing chain is probably all it would need...if that. The piston is probably overkill.
  • brad the best
Posted September 15, 2008 - 06:48 PM
any one know what the compression should be ? with the auto decomp on ?
i guess i could disable it next time i do a valve check and then do a compression test .
  • brad the best
or couldn't you just try and kick it over slowly ?
  • maxtherat
Posted September 15, 2008 - 06:51 PM
Have someone tow you with the bike in gear.
  • lilyamaharacer9
Posted September 15, 2008 - 06:52 PM
No, the auto decompression is always in, no matter how fast you kick it. The leakdown test is your best bet.
  • Thumper_Bloke
Posted September 15, 2008 - 07:29 PM
no power loss? no oil consumption? i wouldn't change a thing!!
  • brad the best
Posted September 15, 2008 - 07:49 PM
ya i was thinking backwards for a second .
  • JSanfilippo
Posted September 15, 2008 - 09:32 PM
One thing with these bikes even w/ the auto decomp there should still be alot of resistance on the kickstarter when you come up on TDC. Unlike the hondas where you could pretty much start them by hand.
If its blowing though TDC like a 426 with the decompression lever pulled in then yes you have problems.
  • MountainMax
Posted September 16, 2008 - 02:26 AM
No power loss, oil comsumption, noise, nothing, i'll leave her for another year then forsure. I have adjusted the valves once when I popped in a YZ exhaust cam.
  • kskyles
Posted September 16, 2008 - 08:07 AM
It's not a dealer, he's an honest guy. My mechanic is the crew chief of warthog racing. He does good work, for a good price.
My rings were worn out, gaps out of spec and had an exhaust valve leak. Cylinder was worn...etc.
If the leak down test is the way to go, then it sounds like the right plan.
Either way, I wish I would have done it last year.
