License Plate Update: 2007 WR450
9 replies to this topic
  • Humunn
Posted September 13, 2008 - 11:44 AM
I originally went with this set up, the $8 Lowes roof vent solution as I wanted to keep the original tail light.
But found I occassionally sucked the plate under when bottoming out. Fortunately the set up is flexible enough that it didn't tatter the plate. But it did torque on the blinkers and they became weak over time. Since originally installing the home made plate holder I've lowered the bike about 1" and after that began sucking the plate under more frequently. It was only a matter of time before I'd be on the trail with a lost plate and mess of broken wires.
So I upgraded to this solution. Not very expensive plus the assembly extends under the fender to add support since I carry a rear fender tool bag. I was concerned how it would look without the factory tail light but I actually like the Baja Design setup. All LED.
Greg
  • WR450FGreg
Posted September 13, 2008 - 12:27 PM
Man, that workshop looks cleaner than my bedroom!
Greg
  • SXP
Posted September 13, 2008 - 01:40 PM
Is that the stock 07 rear fender? If so, what did you do with the threaded plastic posts that the stock light screws into? Shave them off? Can you also post a top view of the fender? Thanks.
  • Humunn
Posted September 13, 2008 - 03:46 PM
Greg
Uh, that is my bedroom...sometimes! :thumbsup:
Greg
  • Humunn
Posted September 13, 2008 - 03:48 PM
Yep, stock fender and yes I took the plunge and clipped all the posts off. No turning back!
The top view is the same as stock except where I drilled four holes to bolt the tail light to. I can still take a pic if it would help. Let me know.
Greg
  • stevs450F
Posted October 06, 2008 - 08:52 AM
Thank's Greg, That seems to be a clean look. I just needed to see how the Baja fender mounted up, they always make products so bulky..
  • Dube2
Posted October 06, 2008 - 01:02 PM
Greg
Hey Greg, nice bike and hard work always pay off.
However........... You'll need to move your rear blinkers due to the exhaust melting the one on the right. Been there, done that. I made a some-what decent bracket that bolted to the top on my fender whare the BD bolts are and mounted them to that. 1.5" away from the hot exhaust and a little more safer from falls. Or just get those small surface mount LED blinkers that could be mounted high up towards the front of the fender and forget about them.
Just my $.02
  • Humunn
Posted October 06, 2008 - 07:42 PM
Just my $.02
It's a bit of an optical illusion. They are mounted about where my old ones were. Been riding with them for days and not a hint of meltdown. I looked at the flush mounts but these were sizing down from my originals and are still DOT approved.
  • skyrider1977
Posted October 08, 2008 - 11:45 PM
where did you get these blinkers? i am looking for DOT blinkers to street legal my bike. thanks :lame:
  • Humunn
Posted October 09, 2008 - 03:52 AM
Baja Designs. I just PMd you.
