Bent Sub-Frame
7 replies to this topic
  • MotocrossManiac
Posted September 12, 2008 - 06:44 PM
I have an '08 YZ450F and wrecked in on Memorial day weekend. Bent the exhuast, handlebars, and sub frame. I was wondering if the sub frame could be bent back? or if anyone knows a good way to bend it back? Thanks for the help.
  • dmoney1074
Posted September 12, 2008 - 06:54 PM
I just use a big tree or a wall....
  • husqy360
Posted September 12, 2008 - 06:56 PM
same here.
  • MotocrossManiac
Posted September 12, 2008 - 07:08 PM
Ha ha ok. That simple eh? Thanks
  • husqy360
Posted September 12, 2008 - 09:41 PM
whem my steel sub frame bent.
i tie a rope to the frame and to a tree , then pull the bent part with a car, or anything you wana try.
but cuz its alu id take those propane tourch and heat the bent part for about 5 min and then hammer it , alu stay hot for long time after 5 min of tourching. so do 1 side then the other, or use 2.
good luck
  • Ga450owner
Posted September 13, 2008 - 05:34 AM
I use a pry bar, 2x4, deadweight hammer to fix
this will work well also
http://www.parktool....=80&item=FFS--2
  • MotocrossManiac
Posted September 13, 2008 - 02:56 PM
good luck
Cool, thanks for all the help. I appreciate it.
  • mxracer206
Posted September 13, 2008 - 05:32 PM
Sorry bout the crash! The easiest way I have found is to cut the cross bar that is by the fender. This is what makes it rigid when all the bolts are removed. You can have your way with it then. Another good thing is an auto body tool, it is a long bar with hooks and a chain that lets you pry things back in shape.
  • Hot  38 replies
  • Hot  50 replies
  • On January 15, 2017
  • 10 replies
  • 3 replies
